Flex-a-lite Fan Pusher or Puller??? #66491
05/31/08 03:08 AM
05/31/08 03:08 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
I'm in the process of installing an electrical fan in my Cuda. The one I have is a 210/220 puller fan.
Problem is, I need a "pusher" fan, because there is not enough room between the radiator and motor. I switched the black and white wires on the fan, and it pushes rather than pulls. Is this OK to do?
I ask because I don't want to burn out the motor or anything like that.
Thanks!!
Re: Flex-a-lite Fan Pusher or Puller??? [Re: Cudalord] #66492
05/31/08 09:22 AM
05/31/08 09:22 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Most cases it will be fine. However a puller is much more efficient for cooling...
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Flex-a-lite Fan Pusher or Puller??? [Re: GoodysGotaCuda] #66493
05/31/08 10:48 AM
05/31/08 10:48 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Why?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Flex-a-lite Fan Pusher or Puller??? [Re: Rug_Trucker] #66494
05/31/08 11:47 AM
05/31/08 11:47 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Because it's not blocking the radiator core.
Re: Flex-a-lite Fan Pusher or Puller??? [Re: Cudalord] #66495
05/31/08 12:36 PM
05/31/08 12:36 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
At a recent show, I saw a car that had two smaller "puller" electric fans, mounted side by side (on either side of the pulley, where the fan would normally be mounted). There wasn't enough room between the pulley and the radiator for a single electric fan. I don't know how effective it would be, but it's another option.
