Speedometer pinion #664686
04/08/10 08:09 PM
04/08/10 08:09 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
When changing pinion gear how fluid will you lose?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Speedometer pinion [Re: 36PLYM] #664687
04/08/10 08:15 PM
04/08/10 08:15 PM
Kirkland, Washington
Pacnorthcuda Offline
None if jack up the drivers side/rear enough.
