5.9 Magnum Balancer...which can I use? #664523
04/08/10 05:01 PM
04/08/10 05:01 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
I have a 98 5.9L 360 I'm using in my 72 Demon. Stock engine, using the stock weighted flexplate with a neutral balanced converter. What choices to I have for harmonic balancers? Does it need to be for internally or externally balanced motors?
Re: 5.9 Magnum Balancer...which can I use? [Re: chache876] #664524
04/08/10 05:24 PM
04/08/10 05:24 PM
Andrewh Online content
Andrewh  Online Content
pretty sure all magnums are neutrally balanced. so no weights on the converter. Someone can correct me if I am wrong.
Re: 5.9 Magnum Balancer...which can I use? [Re: Andrewh] #664525
04/08/10 05:42 PM
04/08/10 05:42 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
If it's stock, it will use a 360 magnum balancer. it's weighted, since the crank is cast. Pre-magnum 360 balancers are different.
Re: 5.9 Magnum Balancer...which can I use? [Re: todd440] #664526
04/08/10 05:47 PM
04/08/10 05:47 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
318 magnums are neutrally balanced, 360s require the magnum 360 balancer. I believe all 360 magnums are balanced the same so you can find one for any of them. Just do not use the 2000+ balancer as the pulley and it are one piece.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: 5.9 Magnum Balancer...which can I use? [Re: blk00rt] #664527
04/08/10 06:00 PM
04/08/10 06:00 PM
Costa Mesa, CA
Costa Mesa, CA
I ask because some of these balancers come with or with out weights, so I need to know if the weights have to go on them or not.
So youre saying get the one with the weights essentially?
Re: 5.9 Magnum Balancer...which can I use? [Re: chache876] #664528
04/08/10 06:14 PM
04/08/10 06:14 PM
that is what I meant. I don't think the magnum balancers use weights.
Re: 5.9 Magnum Balancer...which can I use? [Re: Andrewh] #664529
04/08/10 07:13 PM
04/08/10 07:13 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
They don't have weights, they use a semi-circle groove cut out in the face of the balancer. This is concidered external balance. The amount of weight cut out of one side, makes it heavier in one targeted spot.
Re: 5.9 Magnum Balancer...which can I use? [Re: todd440] #664530
04/08/10 07:17 PM
04/08/10 07:17 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Here is a link. Look at the material removed on the one section.
http://cgi.ebay.com/ebaymotors/360-5-9-D...=item3efe03dd03
Re: 5.9 Magnum Balancer...which can I use? [Re: todd440] #664531
04/08/10 09:50 PM
04/08/10 09:50 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
but a 360 magnum is not the same balance as an LA 360 or cast crank 340, so those balancers won't work (for long)
2017 Grand Cherokee Overland
Re: 5.9 Magnum Balancer...which can I use? [Re: patrick] #664532
04/08/10 10:01 PM
04/08/10 10:01 PM
Costa Mesa, CA
Costa Mesa, CA
Ok guys I got it now. Had it backwards in my head, thanks.
Re: 5.9 Magnum Balancer...which can I use? [Re: chache876] #664533
04/09/10 06:31 AM
04/09/10 06:31 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
some of the aftermarket dampers (the professional products one I know) have bolt-on weights. one of the PP ones is neutral balance and comes with bolt on weights for both cast 340's and for 360's.
