I got kinda bummed out when I finished cleaning this thing up, painted it, checked it to make sure it would work in my Ramcharger, and then was completely shut down on trying to find a filter for it.
I'm not entirely sure of the application it came in, which makes looking for a filter that much more difficult.
The base is roughly 4.50" tall, the overall diameter is roughly 14.25", and the "platform" that the filter would sit in is roughly 9" in diameter. The total height, internally, that the filter would need to be in order to contact both the top and bottom is 3.5". The only markings on it are a stamped word, "FRONT" just offset to the left of the intake snorkel.
I went though EVERY circular filter at the local checker auto. Nothing fit correctly. There was one filter that was the proper diameter, but too short.
I'm not sure if this is from a truck or a motorhome application. Getting an idea would probably be helpful.
Here are a couple shots of it.
Thanks for the help in advance. And sorry about the leatherman measuring device. It's all I had at the time
