6 pack coil bracket #66426
05/30/08 09:49 PM
05/30/08 09:49 PM
Anonymous OP
Anonymous OP
right now my coil is mounted on the passenger fender well.
will the stock 6 pack coil bracket fit on an edelbrock six pack manifold? Or will it only fit an original manifold?
Re: 6 pack coil bracket #66427
05/31/08 01:53 AM
05/31/08 01:53 AM
Anonymous OP
Anonymous OP
Re: 6 pack coil bracket #66428
05/31/08 09:50 AM
05/31/08 09:50 AM
Anonymous OP
Anonymous OP
Should be fine at the back pass side. The 69.5 was an eddy manifold, and that is where it is in factory literature.
Re: 6 pack coil bracket #66429
05/31/08 11:58 AM
05/31/08 11:58 AM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Mine is on an Eddy. It uses the back two intake bolts
Re: 6 pack coil bracket [Re: 500Stroker] #66430
05/31/08 05:16 PM
05/31/08 05:16 PM
Id
mopeman Offline
mopeman  Offline
Id
I've got mine on an Eddy Torker II...
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: 6 pack coil bracket [Re: mopeman] #66431
05/31/08 05:17 PM
05/31/08 05:17 PM
Id
mopeman Offline
mopeman  Offline
Id
Here's another veiw...
Mopar or no car
'93 W250 Ram
'68 Charger
