Torque specs/values when reassembling a Big Block #664212
04/08/10 12:29 AM
04/08/10 12:29 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Im getting mentally prepared to reassemble the timing components on the 400 in my truck.
Wondering what the correct torque specs are on the Bolt that holds the large timing sprocket onto the cam,and what is the torque spec of the large harmonic balancer bolt.
I think the rest are pretty much gauged as "tight is tight" or "snug"(timing cover) or are there any other fasteners that need a special torque value when doing a timing Chain and gears?
Re: Torque specs/values when reassembling a Big Block [Re: SPWC] #664213
04/08/10 03:38 AM
04/08/10 03:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The timing sprocket bolt should be installed with locktite. VERY IMPORTANT. I Torque mine to 30 ft/lbs. I haven't found any specs either, but then again, I DO have a MP engine book here somewhere. It may have the info you need. I'll respond if I can find it.
Re: Torque specs/values when reassembling a Big Block [Re: Kern Dog] #664214
04/08/10 06:43 AM
04/08/10 06:43 AM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
crank bolt 130 ft/lbs
Re: Torque specs/values when reassembling a Big Block [Re: The_Mean_Machine] #664215
04/08/10 07:08 AM
04/08/10 07:08 AM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
