Hood scoops #664057
04/07/10 08:29 PM
04/07/10 08:29 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Was there a gasket material placed around the bottom of the scoops before being installed on the hood? If yes What or suggestion to use. Thanks
Re: Hood scoops [Re: 70 buzz] #664058
04/07/10 08:43 PM
04/07/10 08:43 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
None that I know of.
If you use a gasket it would likely end up as moisture trap and wind up causing surface rust.
Re: Hood scoops [Re: 70 buzz] #664059
04/07/10 08:45 PM
04/07/10 08:45 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
What car? 68 69 Road Runners and GTX's had a gasket under the hood scoops.
Re: Hood scoops [Re: 70 buzz] #664060
04/07/10 08:58 PM
04/07/10 08:58 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
It would sure help if we knew what car, hood, scoop you are asking about.
Re: Hood scoops [Re: rrunner] #664061
04/07/10 10:05 PM
04/07/10 10:05 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
70 super bee
Re: Hood scoops [Re: 70 buzz] #664062
04/08/10 06:43 PM
04/08/10 06:43 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
70 super bee
Well that narrows it down. N96 hood - no gaskets, std hood - not that I remember.
Re: Hood scoops [Re: 70 buzz] #664063
04/09/10 10:48 AM
04/09/10 10:48 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
No gaskets.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
