where to get ac lines ? #66391
05/30/08 09:40 PM
05/30/08 09:40 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
well a squril got me today !
tried to charg the a/c an after two can of 134 and waiting 20 min psi goes lower and lower ???
so get out the ole sniffer and sure enough there it is a section of chewed hose !!!!!!
need the large dia hose for a 1974 dodge dart ,from compressor to firewall .
thank you !
Re: where to get ac lines ? [Re: calrobb2000] #66392
05/30/08 10:56 PM
05/30/08 10:56 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I use a place called Benz Hydraulics here in Delaware.They use the metal fittings from the old lines and install new hose(inexpensive).You probably have a place near you,check your phone book.
Re: where to get ac lines ? [Re: Ply72rr] #66393
05/31/08 12:55 PM
05/31/08 12:55 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Correct...Open up the phone book and look for a local hydraulic hose manufacturer...I'm sure there's a few in your area that services heavy equipment...As stated most good shops can re-use your existing ends for a factory look...
