Re: Who else is running a Powerglide in their Mopar ?
[Re: The Shocker]
#662976
04/06/10 08:52 PM
04/06/10 08:52 PM
Posts: 1,285 okla.
sam64
okla.
me,65 coronet 440 .030,small solid cam,[.557],otb eddy heads,teamg int.,1000 cfm hp,p/g 4500 conv.,4.86 gear,14x32x15 pheonix slicks,3000lbs race wt.footbrake,leave @ 3,000,shift 6500,10.75 @ 125.with only a 1.52 60 ft.
[Re: demongup]
#662977
04/06/10 09:05 PM
04/06/10 09:05 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
wow! I just watched your video on ur link.Scarry looking track you race at.Hope you find you info on the glide.
It is a scarey track .Real narrow and very little shut down.Get outta shape and its gaurd rail city.Its actually an old highway that was turned into a Dragstrip in the late 50's .Its in Temple Texas and its called Little River.I know lots of guys running my ETs and lower that wont race on it to the 1/4 .Its not my home track ,its about 300 miles from me .That run was at a Nostalgia event there last October .Im either a bit braver or dumber than them that wont run mid 11's there , dont know which .At the time my car had no rollbar and just and old rotten lap belt holding me in the seat ...
[Re: sam64]
#662980
04/06/10 09:21 PM
04/06/10 09:21 PM
The Shocker
Sherman Texas
Did your 60 foots change when you switched over from the Torqueflite Sam ? I feel a bit better knowing that my 60' is real close to yours with my little 8.5 slicks .I guess the Dart is hooking pretty good on the slapper bars to go 1.57 60's with the same weight of 3000 lbs .I really dig that Coronet of yours BTW ...
[Re: The Shocker]
#662982
04/06/10 09:29 PM
04/06/10 09:29 PM
Posts: 1,285 okla.
sam64
okla.
the converter in the p/g lets me go 500 rpm more than the one i had in the 727.actually if i would get the proper converter for my combo i would be in the low 1.40's 60 ft.but it's working fine as a bracket car,besides start going faster than 10.00 is a whole other world of rules,and certifications,so i'm good where i am. oh hell,60's are identical.
[Re: Deepockets]
#662984
04/06/10 09:47 PM
04/06/10 09:47 PM
Posts: 976 ontario canada
mac56
ontario canada
have one here also. 8.42 @ 162mph is best. i hope the picture comes up since i've not posted one on this site yet.
Wicked ride man Welcome.
[Re: The Shocker]
#662985
04/06/10 09:49 PM
04/06/10 09:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a glide set up for a BB but I think I will change it over for a SB and put it in my car, I plan on a 5800 - 6000 stall, car is 2400# with a 405ci W-9, currently with a 1.20 to 1.21 60'... I wouldnt mind if the 60' was a 1.25 or better
Post deleted by Defbob
[Re: Deepockets]
#662986
04/06/10 10:04 PM
04/06/10 10:04 PM
#662987
04/06/10 10:17 PM
04/06/10 10:17 PM
Posts: 2,499 PA
moparacer
PA
Run glides in my cars since the 90's in everything from a alky injected 360 small block Dakota to a small block Dragster and now a big block Dart.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: jamesc]
#662989
04/06/10 11:10 PM
04/06/10 11:10 PM
Posts: 2,864 IN
Irun5snd8th
IN
Put one in mine at the end of last year and I love it. 3000lbs 416 small block. Fastest the car had been in the 1/8th was 6.22 with the setup at the time and I went 6.26 with the glide in it. I will say it honestly lost .04 in 60 ft and .06 total.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#662990
04/07/10 01:37 AM
04/07/10 01:37 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
There has been a glide in this car for 20 years. Run a 1.76 stock planetary. Going to a 1.80 straight cut for my next transmission.
Weighs 3328 with me in it. 6.50's in the 1/8th with a 493" pump gas motor.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: The Shocker]
#662991
04/07/10 06:46 AM
04/07/10 06:46 AM
Posts: 694 Michigan
Super Scamp
Im just curious who else is running a Powerglide in their Mopar Dragcar.Tell me a little about your setup in your car if you dont mind.Stuff like weight ,motor ,gears ,tire height ,convertor ,Et and mph ,would be great to know,Thanks ...
92 Daytona 572" 5500 stall Abruzzi Glide, 15x32, 4:56 gear,runiing 75/25 1050, 1/8 running 5:50 and 1/4 8:70 with no spray.
weight is 2500 with out driver, Driver on diet lol
Just One Man's Opinion
Mopar Mafia Racing
[Re: Super Scamp]
#662992
04/07/10 07:24 AM
04/07/10 07:24 AM
#662993
04/07/10 07:34 AM
04/07/10 07:34 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
I run a Coan glide in mine! I dont think I could hook it up to the track without the glide. Not on the true 10.5 tire anyhow.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
