lower ball joint help needed. #66291
05/30/08 05:33 PM
05/30/08 05:33 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, whats the best way to separate the lower ball joint from the LCA. I bought the tool from mancini and it didnt work at all. I turned it as much as I could even with a breaker bar and it didnt pop them loose. I think I started stripping the threads in the tool. Is there an easier way to do this. Thanks in advance.
Re: lower ball joint help needed. [Re: 440forPOWER] #66292
05/30/08 05:43 PM
05/30/08 05:43 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Usually that IS the easier way is using their tool. Are you reusing the ball joint, or replacing it? Another good alternative if you have a decent air compressor is a phenumatic air chisel with the pickel fork end. That usually makes short work of it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: lower ball joint help needed. [Re: 440forPOWER] #66293
05/30/08 05:46 PM
05/30/08 05:46 PM
BDW Offline
BDW  Offline
I was able to get mine out with a pickle fork. If that doesn't work, I would put the nut back on, support the LCA, then hit it with a 3lb hammer.
Re: lower ball joint help needed. [Re: BDW] #66294
05/30/08 06:44 PM
05/30/08 06:44 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Mr. Pickle fork meet Mr. Ball joint, Mr. Three pound hammer, meet Mr. Pickle fork.
Brut force is needed here. Replacement boots are available
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: lower ball joint help needed. [Re: 440forPOWER] #66295
05/30/08 06:48 PM
05/30/08 06:48 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Smack [with a BFH] the part of the LCA through which the tapered stud passes.
It's what every [clever] flat-rater does.
Down to just a blue car now.
Re: lower ball joint help needed. [Re: R70RUNNER] #66296
05/30/08 07:16 PM
05/30/08 07:16 PM
Lincoln NE
super gas
super gas
Lincoln NE
I tried the pickle fork I have. But it wasn't thick enough as I could pound it all the way without it popping the ball joint free.
Re: lower ball joint help needed. [Re: 68HemiB] #66297
05/30/08 08:16 PM
05/30/08 08:16 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Lossen the nut, but do not remove the nut from the ball joint. Have a buddy hold a BF hammer on one side of the cast section where the ball joint tappered section passes thru. You hit the other side of the cast section with BF hammer. Should separate with about 3 blows of the BFH.
Ron
Re: lower ball joint help needed. [Re: Ronnman] #66298
05/30/08 08:53 PM
05/30/08 08:53 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Make sure to use some hearing protection if you go the BFH or Pickel Ford Air Chiesel route. Not cool, but smart.
2020 RAM 1500
