Reasonably Priced One Wire Alternator for Mopar?? #66266
05/30/08 04:40 PM
05/30/08 04:40 PM
Perry, OK
tkulak Offline OP
tkulak  Offline OP
Perry, OK
Is there a reasonably priced one wire alternator for the Mopar similar to the one wire Chevy setup? I would like to ditch the external regulator. Any input appreciated.
Re: Reasonably Priced One Wire Alternator for Mopar?? [Re: tkulak] #66267
05/30/08 04:50 PM
05/30/08 04:50 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I run a Powermaster 140 amp 8-47529 roughly $210 on my 340
and am getting a MSD 160 amp 5111 roughly $371 for my big block
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Reasonably Priced One Wire Alternator for Mopar?? [Re: RylisPro] #66268
05/30/08 05:50 PM
05/30/08 05:50 PM
IN
ahy Offline
ahy  Offline
IN
If your power needs aren't much higher than stock, a Chrysler style 75A Power Master one wire alternator would work. Have a look at Mancini or Bouchillon.
The GM style 140 A unit can be a tight fit/no fit on a BB especially with aluminum heads. I bought one and had to return it ("B" engine with Edelbrock heads).
Re: Reasonably Priced One Wire Alternator for Mopar?? [Re: ahy] #66269
05/30/08 06:29 PM
05/30/08 06:29 PM
Perry, OK
tkulak Offline OP
tkulak  Offline OP
Perry, OK
Yeah, I'm running Edelbrock Aluminum heads and a Max Wedge Intake from A & A. I have the Bouchillon alternator bracket and low mount A/C bracket and shorty A/C compressor. I have MSD ignition and 6AL box. Not sure how many Amp Alternator I should run. Wondering if I could run a GM one wire for simplicity but also looking at compact versions. Just trying to see what other people have run into and what they did to solve problem.
Re: Reasonably Priced One Wire Alternator for Mopar?? [Re: tkulak] #66270
05/30/08 06:41 PM
05/30/08 06:41 PM
IN
ahy Offline
ahy  Offline
IN
The 75A Chrysler style should provide enough juice for what you're running.
Re: Reasonably Priced One Wire Alternator for Mopar?? [Re: ahy] #66271
05/30/08 09:46 PM
05/30/08 09:46 PM
St. Catharines, ON
N
NewMemberAgain Offline
super street
super street
N
St. Catharines, ON
I run the 75/80 amp powermaster amp. You can get this is a one wire with single or dual groove pulley.
It also comes in your choice of natural, or a nice chromed look!
It will also hook right back up to your brackets, as its nothing more than a stock re-worked casing with an internal regulator on top.
Bryan
