Re: Valve lash problems
[Re: camastomcat]
#662189
04/06/10 08:40 AM
04/06/10 08:40 AM
Posts: 1,226 Peoples republic of clackamas ...
atoetly
Tom what I mean by preload condition is at tdc the valves are held .005 open. If I set them at zero lash cold at tdc to remove this I would have more lash than calls out on the cam card when the engine is warm. My other concern here about excessive lash is I'm running a set of all composite lifters and want my lash kept at the utmost minimum.
[Re: RonP]
#662192
04/06/10 09:00 AM
04/06/10 09:00 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I was told also by a Big Time Mopar Man that Mopar engines need the exhaust valve about 1/2 open to set intake. When I set mine this way it runs a lot better.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#662193
04/06/10 09:31 AM
04/06/10 09:31 AM
MRMOPAR622
Sweet Home Alabama
Atoetly, I have found on my camshaft .012-.012 HOT. Its very hard to get both valves closed.When one shuts the other is opening at the same time.
I also have a aluminum block and heads. I was told to warm the engine up to 145 degrees to set valves.I like to get it up to 175 at least. What temp. does everyone else use.
[Re: atoetly]
#662195
04/06/10 10:53 AM
04/06/10 10:53 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I never checked my whether the valves hang open cold, but I don't see how they can if you still have lash clearance, but it doesn't take it long once it wamrs up to change the settings.
[Re: atoetly]
#662199
04/06/10 03:32 PM
04/06/10 03:32 PM
Posts: 1,880 USA
Ron Silva
USA
My last solid roller had an eccentric shaped base circle so I did what cab said (to find the loosest spot). I then plugged that info into the 8 position chart for valve adjustments and used that. So I had to take the cylinder numbers on the chart and slide them down a coulpe and re-did the chart in Word program on my computer and printed out a bunch of copies. That way I can just check off each valve as I go with a pencil.
SRT DEMON ONE SEAT
[Re: atoetly]
#662204
04/06/10 07:48 PM
04/06/10 07:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One of the guys I know will not run his engine cold, he has alum block and heads, he uses a block heater to warm it to 140* before he even thinks about firing it... so if you were to warm the block it wouldnt matter if your valve is partly open while cold ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#662205
04/06/10 08:26 PM
04/06/10 08:26 PM
Posts: 3,695 nc
emarine01
nc
Other way around, no ![](/ubbthreads/images/graemlins/beer.gif) My bad, ![](/ubbthreads/images/graemlins/hammer.gif) never mind
