440Source math problem? #661955
04/05/10 10:31 PM
04/05/10 10:31 PM
Ontario, Canada
Stanton Online content OP
Don't question me!
Stanton  Online Content OP
Don't question me!
Ontario, Canada
Got a 440Source stroker kit for an RB ...
4.375 stroke crank
7.1 rods
1.423 comp. height pistons
.009 deck height (down the hole)
10.725 stock 440 deck height
so...
4.375/2 = 2.1875
+ 7.1
+ 1.423
+ .009
= 10.7195 ??? What gives ... where's the .0055 gone ???
This is critical stuff !!!
Re: 440Source math problem? [Re: Stanton] #661956
04/05/10 10:38 PM
04/05/10 10:38 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Any chance that's a typo from 440source on the compression height?
Re: 440Source math problem? [Re: Stanton] #661957
04/05/10 10:49 PM
04/05/10 10:49 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thats very typical. Many combos are figured for 10.720 as to allow for a -.005 clean up cut off the decks to provide a square , clean deck surface as most old blocks need it, and to be honest, most new blocks deck surface finish is pretty poor. If you need to use Cometics or any other MLS gasket, that .005 will give you enough room to correct the RA for proper finish.
RIP Monte Smith
Re: 440Source math problem? [Re: Stanton] #661958
04/05/10 10:55 PM
04/05/10 10:55 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I'd contact Brandon( before yet another inflammatory 440 source post) and let him know....If you really spent money with him and aren't just trolling about a math error on his website. The difference could be taken up with a cleanup deck.... Ma Mopar wasn't that careful with deck heights. Good Luck with that.
BTW I checked a few other combos listed on his site, funny thing, that's the only one with a deck height error
Re: 440Source math problem? [Re: Skeptic] #661959
04/06/10 12:03 AM
04/06/10 12:03 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Oh, I spent the money all right !! The block's in being machined and we want to zero-deck it based on the numbers but we need to know if they're correct first.
I'll likely make the phone call tomorrow.
Re: 440Source math problem? [Re: Stanton] #661960
04/06/10 12:10 AM
04/06/10 12:10 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
hopefully onto the table of the mill that squaring the block to where it should be. stock deck heights are all over the place. better to have is stack up a little short for clean up room then have it too tall. as mentioned i would consider this common practice not a math error.
Re: 440Source math problem? [Re: 446acuda] #661961
04/06/10 12:38 AM
04/06/10 12:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What it likely is is a typo on the in the hole dimension.. Allot are calculated @.014 in the hole.. This one probably winds up .0145 in the hole.. & I'd be decking the block to 10.710 FWIW I originally decked my current build at 10.720 being conservative & since have shaved another .010 off...
Re: 440Source math problem? [Re: Stanton] #661962
04/06/10 12:50 AM
04/06/10 12:50 AM
AndyF Offline
AndyF  Offline
What exactly is the problem? You deck the block to match the rotating assembly.
All the piston vendors assume the deck is shorter than blueprint because they are selling parts for 40 year old engines.
Re: 440Source math problem? [Re: AndyF] #661963
04/06/10 02:07 AM
04/06/10 02:07 AM
Boise
Moparteacher Offline
Boise
I agree. I decked my 383 .050" to get the piston where I wanted it.
Now just hope the crank and rods are as advertised.
Re: 440Source math problem? [Re: AndyF] #661964
04/06/10 03:42 AM
04/06/10 03:42 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You do a mock up assembely and measure how far each piston is in the hole so you can square it and mill correctly. I would sooner do that than go off of advertised lengths.
Re: 440Source math problem? [Re: DaytonaTurbo] #661965
04/06/10 05:47 AM
04/06/10 05:47 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I have friends who think I was crazy to have the bores done first so i could fit the oversized pistons and do a mockup assembly in order to find the true deck height I needed afterwards.
IMO taking your time and getting things right is worth the extra trip to the machine shop.
Id rather do that, than end up with the compression all wrong, or a problem I can't correct afterwards because i put my head in the sand.
Re: 440Source math problem? [Re: Stanton] #661966
04/06/10 07:07 AM
04/06/10 07:07 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's only .0055 thou the decks are more often 10.720 than 10.725 and they like to leave a little to square the decks and resurface them. .0055 is not much and would make less than .2 compression difference you would never notice it. My stroker (RIP) needed .015 to square and surface the 40 year old flaws out of the deck. when machinist said they were stock (i did not hear that he wanted .015 to square and resurface) I ordered my custom pistons to be 10.720 0 deck and when we actually started the machining I had to have my pistons cut down .010 or my piston to head clearance would have been .028
Re: 440Source math problem? [Re: Stanton] #661967
04/06/10 08:04 AM
04/06/10 08:04 AM
wappinger falls new york
Jimi_Vignogna Offline
4.375 stroke crank
7.1 rods
so...
4.375/2 = 2.1875
nominal deck on an rb is 10.720, if it was mine i would make the deck 10.700 and if the pistons are above deeck buy custom cometics in the thickness you need to make the required deck ht. square deck the block first then bore it not vice versa!!!!
+ 7.1
+ 1.423
+ .009
Re: 440Source math problem? [Re: Stanton] #661968
04/06/10 09:50 AM
04/06/10 09:50 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
4.375 stroke crank
7.1 rods
so...
4.375/2 = 2.1875
+ 7.1
+ 1.423
+ .009
IMO. Not that critical.
Re: 440Source math problem? [Re: BobR] #661969
04/06/10 10:25 AM
04/06/10 10:25 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If you want the real(correct) math,you should install the crank,rods and pistons at all 4 corners,then make your measurments and do the machine work if necessary base on the actual numbers or if you have an accurate way of measuring the block at crank center.
Re: 440Source math problem? [Re: Stanton] #661970
04/06/10 11:19 AM
04/06/10 11:19 AM
organ
maximum entropy Offline
organ
4.375 stroke crank
7.1 rods
so...
4.375/2 = 2.1875
+ 7.1
+ 1.423
+ .009
easy there, chief! take a deep breath- there. that's better. is this your first engine? suppliers NEVER sell combos that are zero deck in an unmachined "nominal deck height" block. AND, as an added bonus, they'll give you compression ratios and deck heights based on a number they've pulled out of a hat! some will give you deck height based on -.010 deck ht, some -.015, and so on. ALWAYS mock up and measure YOUR deck height before machining, to avoid "nasty surprises". ALWAYS. if it's off, it's your fault. sorry.
Re: 440Source math problem? [Re: B G Racing] #661971
04/07/10 12:27 AM
04/07/10 12:27 AM
I use one piston(no rings on it) and rod on all four corners, mark all the measurments down. Don't be suprised on a stock OEM motor to have taper front to back(or visea -versa) as well as a different deck hieght on one side versus the other side. OEM machine work was not even close to blueprint specs on al the Mopar motors I have blueprinted
Re: 440Source math problem? [Re: Stanton] #661972
04/07/10 12:36 AM
04/07/10 12:36 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Get the deck height correct, then order parts to fit that spec. Or cut it down to what a shelf kit needs.
Sounds like you are in the latter.
I want my fair share
Re: 440Source math problem? [Re: SomeCarGuy] #661973
04/07/10 07:03 AM
04/07/10 07:03 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
ya same way i did mine had it ruff bored, fitted pistons in every cyl to check deck height and rod clearance, then sent it back for final decking and hone. ive learned the hard way to do it right the first time
Re: 440Source math problem? [Re: Cab_Burge] #661974
04/07/10 07:51 AM
04/07/10 07:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We usually install the oil ring to make sure the piston is centered in the bore and not cocked,if not it can be off the amount of the wall clearence usually .005
