68 roadrunner headliner question? #661081
04/04/10 10:24 PM
04/04/10 10:24 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Is it hard to install a headliner in a 68 Roadrunner?
Re: 68 roadrunner headliner question? [Re: bobs69] #661082
04/04/10 10:57 PM
04/04/10 10:57 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
its not really that hard but if you dont have patients and a heat gun id let apro do it for a feww bucks.
Re: 68 roadrunner headliner question? [Re: moparsquid] #661083
04/05/10 06:06 PM
04/05/10 06:06 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
:i agree: I did a couple and pulled my hair out. I'm not big on patience. lol Now i have the upholstery shop do them.
Re: 68 roadrunner headliner question? [Re: Dougsmopars] #661084
04/05/10 10:55 PM
04/05/10 10:55 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Yeh..it can be a pain. The sections from the rear window forward are easy...it's getting the sail panel areas tight and glued down that's the pain.
Don't know why Mopar didn't use the "teeth" along the parcel shelf edge like they ended up doing with the E-Bodies.....makes getting the headliner nice and tight in the sail area.
And beleive me...the LESS glue you use makes for NOT getting it all over the headliner when installing!! DAMHIK!
But once you've done one....you'll feel like a pro!
Re: 68 roadrunner headliner question? [Re: superwrench] #661085
04/06/10 12:09 AM
04/06/10 12:09 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The professional upholstry shop that did my Charger, said is was are real challenge...
They use a steam gun to get the wrinkles out and pull it tight..
Re: 68 roadrunner headliner question? [Re: sthemi] #661086
04/06/10 12:17 PM
04/06/10 12:17 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
I'm fairly handy with this kind of stuff, but I wouldn't do it again. (68 Charger). Sail panels are hard. Having done it once, I wouldn't try to do it again. (i.e. - I think the 2nd try would still look like crap at the sail panels).
Re: 68 roadrunner headliner question? [Re: Gusteve] #661087
04/06/10 12:23 PM
04/06/10 12:23 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Ummm...I did mine and its not that bad. Maybe mine was easier because I had the glass out of the car I did some reasearch here and got a bunch of little clips to put it in place and it may have taken me 3 hours total. I figured the worse that can happen is I waste $90 in material. The wrinkles all come out in a couple days by themselves if you streach it good.
I figure that part of the hobby is doing this stuff by yourself.
