big block boat oil pan ? #660426
04/04/10 08:40 AM
04/04/10 08:40 AM
moparx Offline OP
moparx  Offline OP
anyone know how much these hold ? anyone ever run one on the street ? it would have to be used on something that could use a "dragster" type pan, so that would rule out most everything except an engine swap of some sort.
Re: big block boat oil pan ? [Re: moparx] #660427
04/04/10 10:28 AM
04/04/10 10:28 AM
Where (front to rear) is the sump located and how long is it and how deep and what kind of baffling
Re: big block boat oil pan ? [Re: moparx] #660428
04/04/10 11:18 AM
04/04/10 11:18 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've got one here...could get it down and measure it if you wanted It is the kind with the swinging pickup and the pan is cast aluminum.
How would you measure how much it holds? You would not fill it completely full of course ?
Re: big block boat oil pan ? [Re: OzHemi] #660429
04/04/10 11:18 AM
04/04/10 11:18 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: big block boat oil pan ? [Re: OzHemi] #660430
04/04/10 11:19 AM
04/04/10 11:19 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: big block boat oil pan ? [Re: OzHemi] #660431
04/04/10 04:20 PM
04/04/10 04:20 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
OZZIE .....WHERE do you come up with this stuff ? .. that has to be for like a 40 foot cabin-cruiser ! ....and that PROBABLY holds 3 CASES of oil !!
I have a pan for my 18 foot hydro that is around 14 quarts. You NEED that kind of capacity since there is not good air-cooling-effect like on a open-air automotive application.
Re: big block boat oil pan ? [Re: dOoC] #660432
04/04/10 04:49 PM
04/04/10 04:49 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Here and there...
(And it's not really all that big.. )
Re: big block boat oil pan ? [Re: OzHemi] #660433
04/04/10 04:50 PM
04/04/10 04:50 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oh, and I have the matching timing cover for it too..
Re: big block boat oil pan ? [Re: OzHemi] #660434
04/05/10 09:17 PM
04/05/10 09:17 PM
moparx Offline OP
moparx  Offline OP
that's the pan oz. i got a complete engine[well, i should say my pal crowbait does], and thought that pan would be different to use on my 33 dodge humpback. i got more than enough clearance to use it. just wondered if there would be any problems in using it on the street. i can't swim, so i won't be near the water[i hope !]
