Easy way to adjust door to fender gap with fender on? #659768
04/03/10 11:51 AM
04/03/10 11:51 AM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Hey,
For some reason my door to fender gap seems to have gotten smaller on my 70 Charger RT.
Is there an easy way to adjust the gap wider with both the fender and door already installed...the grille,front valence and bumper are also on.
Re: Easy way to adjust door to fender gap with fender on? [Re: Blakcharger440] #659769
04/03/10 12:11 PM
04/03/10 12:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hows the gap between the door and 1/4 panel?
Re: Easy way to adjust door to fender gap with fender on? [Re: stumpy] #659770
04/03/10 01:15 PM
04/03/10 01:15 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
To get them perfect you need to start with gap at door and quarter. Quarter doesn't move so you start with the gaps of door there between door and quarter and door and rocker. When there perfect then you move to front fenders. If not done correctly you could end up with the hood not fitting right because one fender may be to far forward.
Re: Easy way to adjust door to fender gap with fender on? [Re: Dougsmopars] #659771
04/03/10 01:36 PM
04/03/10 01:36 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You may want to rebuild hour hinges before you start moving things. Get a hold of this kit http://www.restorick.com/proddetail.asp?prod=DrHingeRebuildKit
