Re: Timing tape
[Re: cday]
#659387
04/02/10 10:39 PM
04/02/10 10:39 PM
RapidRobert
You could mark the dampener your self. .0632683" around the circumference is 1 degree so w your vernier calipers measure out and make some marks on a long strip of paper then use it as a ruler to make magic marker marks at various points on the dampener. 5 deg is .316". 10 deg is .633". 35 deg is 2.214". 38 deg is 2.404". 5.694" is 90 deg. 11.388" is 180 deg. 17.082" is 270 deg. I would check true TDC w the cheap spark plug piston stop 1st. If you use a timing tape clean/scuff/clean the surface before you stick on the tape then spray it w some clear lacquer to glue it on there so it will stay put. EDIT cut a strip of paper 23" long and any generic timing tape for a 7.25" dampener will work
