Re: Transgo TF-2 instructions anyone? [Re: John_Kunkel] #659327
04/07/10 12:09 AM
04/07/10 12:09 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I agree with John and as a side note, you don't want to run a wire brush in the bores, the corners should be nice and sharp to keep tiny particles from wedging between the valve and the bore. Also you don't really want to clean the valves with anything that will take the sharp corners off. It will make them slide nice and easy on the bench but can cause problems when running.
Re: Transgo TF-2 instructions anyone? [Re: HotRodDave] #659328
04/07/10 09:18 AM
04/07/10 09:18 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
I have another transmission in the works right now, just hate junking something without knowing why it went bad.
Thats why I'm messing with this one still.
Re: Transgo TF-2 instructions anyone? [Re: 1BAD68] #659329
04/13/10 01:31 PM
04/13/10 01:31 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Did you dig into it any deeper ???
Remove the tailshaft/governer etc.
Anything else
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
