Power steering pump pulley swap #659122
04/02/10 05:13 PM
04/02/10 05:13 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I need to swap the small block pulley on my saginaw PS pump for a big block.
Are they pressed on? I don't see a bolt head. The center shaft does accept a 3/8" allen wrench.
How do you remove them and put a new one on without damaging the pump?
Thanks,
Re: Power steering pump pulley swap [Re: nd65] #659123
04/02/10 07:21 PM
04/02/10 07:21 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
If there's no nut it's a pressed style. You will need the tool to remove it and the tool also comes with the installer. You can get a cheapy at Harbor Freight or some of the parts stores lone them out.
Re: Power steering pump pulley swap [Re: rrunner] #659124
04/03/10 06:42 AM
04/03/10 06:42 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I won't have to do the swap after all. A buddy set me up with everything I need tonight.
Thanks,
