air grabber scoop rivets #65885
05/29/08 09:39 PM
05/29/08 09:39 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Is there anything special about the rivets to attach the air grabber scoop to the hood? Are they local hardware stuff or do I have to get ones specific to the air grabber? If I can buy them from Ace Hardware does anyone know what size to ask for? I have a 70 RR if that makes a difference. Thanks
Re: air grabber scoop rivets [Re: gregok] #65886
05/31/08 03:52 PM
05/31/08 03:52 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Any help out there?
Re: air grabber scoop rivets [Re: gregok] #65887
06/02/08 07:08 PM
06/02/08 07:08 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I can tell you that Ace has them and that they are almost identicle to real ones...forget the size but if you go look at the rivets on the hook it will be pretty obvious due to the large head.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: air grabber scoop rivets [Re: Kowal] #65888
06/02/08 11:11 PM
06/02/08 11:11 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks, that was what I was looking for.
Re: air grabber scoop rivets [Re: gregok] #65889
06/04/08 01:33 PM
06/04/08 01:33 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: air grabber scoop rivets [Re: gregok] #65890
06/04/08 04:45 PM
06/04/08 04:45 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Take the pic of what e-bay'rs are selling as exact rivets and Ace will get you very close. I think I bought a clamshell of 25 rivets for about $3.00. They worked great and also have the rivet hand gun you need to make it work...half what the resto stores sell it for.
I am sorry, but installed I can barely tell the difference between my Ace rivets and originals. Depends if you are being judged at the Mopar Nats or not I guess.
Re: air grabber scoop rivets [Re: Kowal] #65891
06/04/08 07:58 PM
06/04/08 07:58 PM
badblack68 Offline
badblack68  Offline
Maybe I`ll try buying them at Ace Hardware. Their price seems lower than the wholesale price I`ve been paying and I buy them in 500 count boxes.
Re: air grabber scoop rivets [Re: badblack68] #65892
06/20/08 09:51 PM
06/20/08 09:51 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Ace part number 2014405
Re: air grabber scoop rivets [Re: Kowal] #65893
06/21/08 04:08 AM
06/21/08 04:08 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
not what you were asking,but on my 70 runner i put silicone on and in the pins (that hinge the door,and our covered by the shark teeth decal) it keeps the decal from ripping when the scoop opens and closes. i know not what you were looking for but a tip i thought i would share
Re: air grabber scoop rivets [Re: meepmeep70] #65894
06/21/08 07:10 AM
06/21/08 07:10 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Am I wrong or don't the rivets hold a 69 air grabber to the hood? My 70, bolts to the metal bracket on the underside????????? Just asking.....
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: air grabber scoop rivets [Re: MoparJunkie] #65895
06/21/08 07:46 AM
06/21/08 07:46 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I do think that the rivets are for 69 only
Re: air grabber scoop rivets [Re: Kowal] #65896
06/21/08 11:18 AM
06/21/08 11:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
there is a row of screws on either outer end of the side air boxes but 69 used rivets otherwise
Re: air grabber scoop rivets [Re: JohnRR] #65897
06/21/08 09:43 PM
06/21/08 09:43 PM
New York, USA
fluegelmeister Offline
New York, USA
What I need for a 70 is the 10 studs that hold the fiberglass air grabber to the base of the hood. They are flat on one side and welded to the bracket that is welded to the hood if that makes any sense.
Barry
Re: air grabber scoop rivets [Re: fluegelmeister] #65898
06/21/08 10:53 PM
06/21/08 10:53 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i know the studs you speak of,but didn't think it was possible to replace without seperating from hood skin. good luck maybe you could make one with the correct thread,once in place nobody would be able to tell. just a thought
Re: air grabber scoop rivets [Re: meepmeep70] #65899
06/30/08 02:44 AM
06/30/08 02:44 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
70 RR air grabber does not have any rivets to mount to hood. It has studs that are tack/spot welded to flange on underside of hood. Do not know of a way that they can be replaced without removing the flange from hood. To do this you have to drill out several spot welds.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: air grabber scoop rivets [Re: 70gtx440dana] #65900
07/05/08 06:00 PM
07/05/08 06:00 PM
badblack68 Offline
badblack68  Offline
I had a 70 GTX airgrabber car. Two of the stids snapped off. They were easily welded back on with a tig welder.
