Re: 383 won't start when hot [Re: GOLDMYN] #658455
04/02/10 11:41 PM
04/02/10 11:41 PM
MNobody Offline
MNobody  Offline
Did you check the timing?
Re: 383 won't start when hot [Re: GOLDMYN] #658456
04/02/10 11:57 PM
04/02/10 11:57 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
thank-you, any chance it might be the starter relay on the firewall?
If you want to rule out the relay, you can jumper across the two terminals on the starter itself with a wire or screwdriver, and see if your symptoms improve.
This test is similar to jumping across at the starter relay on the firewall, but even more direct. If you have bad wire connections anywhere, or bad wiring, this will show you.
I had a burnt brown wire once--the starter would crank strong when jumpered at the starter, but crank weakly or just click when jumpered at the relay.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 383 won't start when hot [Re: wingman] #658457
04/03/10 01:52 AM
04/03/10 01:52 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I was wrestling with a hot start issue with my 383 Cuda last summer. Finally ended up putting in one of the mini-starters from a late model ram pickup.
Hot start issue disappeared. Difference in fire up was AMAZING due to the speed of the mini-starter. Now it starts like a new car, although every now and then I miss the old growl of a "real" mopar starter.
Re: 383 won't start when hot [Re: rss] #658458
04/03/10 09:17 AM
04/03/10 09:17 AM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
I'm taking the weekend off and we'll tackle the problem next week, thanks for all the comments and we will check the timing along with all the other suggestion.
Semper Fi
Re: 383 won't start when hot [Re: GOLDMYN] #658459
04/03/10 11:14 AM
04/03/10 11:14 AM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Perhaps the Carb is an issue. You did not specify what you are running. But with my 383 4bbl I have a cracked carb. It is from Edelbrock which I come to find out are crap. Might check that as well. Mini starter is the only way to go. Dump that antique Mopar unit for the newer mini starter...
Re: 383 won't start when hot [Re: CR8CRSHR] #658460
04/03/10 08:53 PM
04/03/10 08:53 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
How about Vapor lock...if you are boiling the fuel over because the heat of the engine rises due to insufficient cooling when the engine is off, the fuel will turn into vapor inside your fuel line. When your engine cools down enough the fuel becomes a liquid state again, ready to fire up again.
Try a Phenolic spacer
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 383 won't start when hot [Re: Pyper70] #658461
04/04/10 02:34 AM
04/04/10 02:34 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Original poster stated car turned over slowly (like dead battery) when hot. That would not result from a hot fuel/vapor lock type of issue.
My money is on the starter.
Re: 383 won't start when hot [Re: GOLDMYN] #658462
04/07/10 07:29 PM
04/07/10 07:29 PM
Kenosha, WI wi/il border
BobN Offline
BobN  Offline
what about a banana in
the tailpipe(as in singular)? No? just wondering.
So what is the update on this situation ?
Re: 383 won't start when hot [Re: BobN] #658463
04/08/10 03:15 PM
04/08/10 03:15 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Looks like MNoBODY wins the free trip trip to ARUBA with the sex star of his choice...the timing was advanced a good 15 degrees and to be safe, I put a lightweight starter and new cables on. Its going to be awhile before I can dupicated driving condition but I think I got it...Thanks for all the suggestions
Semper Fi
Re: 383 won't start when hot [Re: GOLDMYN] #658464
04/08/10 04:12 PM
04/08/10 04:12 PM
Are you sure it wasn't eng friction/dirty cables/bad battery or the starter . Glad ya got it
Re: 383 won't start when hot [Re: 52savoy] #658465
04/08/10 04:39 PM
04/08/10 04:39 PM
Loveland Colorado
jake71 Offline
jake71  Offline
Loveland Colorado
CLAMP ON AMP PROBE
I've used them on 240-440 phase AC motors and starter relays but never used one on 12v DC.
But if you have a probe, clamp it over the battery to starter cable and watch it as the engine heats up. If the AMP reading changes as the motor heats up, it's either the starter or cable or both.
Clamp on style amp probes only work on alternating current.
http://www.sears.com/shc/s/p_10153_12605...00001&aff=Y
Re: 383 won't start when hot [Re: jake71] #658466
04/10/10 03:05 PM
04/10/10 03:05 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
The weather was nice today so we took the Coronet out for a 40 mile trip, got it nice and hot, came home and shut it off.... and hit the key....started right up!! thanks again Moparts
Semper Fi
Re: 383 won't start when hot [Re: GOLDMYN] #658467
04/10/10 04:55 PM
04/10/10 04:55 PM
Port Hope, Ontario
TheMoparJunky Offline
mopar addict
mopar addict
Port Hope, Ontario
If your voltage regulator ever becomes a problem, check the temp on it. It is just a resistor. They will get hot but not paint melting hot, usually you can check the ohms across it(I think-there is a test). But I have overhauled 1 starter 3 times and each time trued the commutator, cleaned the brushes and checked it for normal voltage drops but it still would eat it up after being hot. Armatures and stators will go bad. The windings might short internally and never be noticeable from the outside. And it's cheaper to get a new armature than spending the money to rewind it. Heat shields work, larger positive cables and ground cables(I've used welding cables-they seem to work fine). Make sure you have a good ground and your solenoid is good across the poles, (for 4 speeds-proper clutch pedal play). It is just a math problem-take out the variables.
Compression should never be an issue-11:1 motors start up fine with just a high amp battery.
But more vacuum will create more work for the rotating assy.-i.e.-turning with the throttle closed is harder than with it wide open-it's gotta suck harder through a smaller orifice.
The Mopar Junky
Back off the Mopar bandwagon- Wannabe Millwright Enjoying the fat lazy unemployed life
