383 won't start when hot
#658435
04/01/10 08:30 PM
04/01/10 08:30 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Hi, I'm looking for possible solutions: 67 coronet 383 2bl, auto, point distrbutor, car runs great, accelerates good and does not ping or run on after being shut off. factory heat guage within spec and does not boil over when shut off. starts great when cold but barley turnes over after driving 25 miles.When I say barley turnes over I mean perhaps 1/2 a crank and the battery sounds dead, yes it has started, but somethings not kosher. any comments will be appreciated....thanks...ps....I just went out after letting it cool down (45 minutes) and the car starts great
Semper Fi
Re: 383 won't start when hot
[Re: GOLDMYN]
#658436
04/01/10 08:43 PM
04/01/10 08:43 PM
RapidRobert
heat soak in the starter. battery internal cell going bad. cables/terminals need cleaning. eng friction sky high when hot. In order: easy to sub in a known good batt then clean (all large)cables from post to post then check turning torque w 1&1/4" socket/breaker bar when hot then another starter
[Re: RapidRobert]
#658437
04/01/10 09:17 PM
04/01/10 09:17 PM
GOLDMYN
Kenosha, Wi
Thanks, but why would the car start great after 45 minutes of cool down if 1. bad connections, 2. battery cell bad? and I don't understand what the 1 1/8 socket would do? . what would cause sky high friction?
Semper Fi
[Re: stumpy]
#658439
04/01/10 10:03 PM
04/01/10 10:03 PM
GOLDMYN
Kenosha, Wi
Thanks, Suppose the engine DOES turn over harder when hot. What would be the cause?. This motor has been rebuilt.
Semper Fi
[Re: Dodgem]
#658441
04/01/10 10:56 PM
04/01/10 10:56 PM
GOLDMYN
Kenosha, Wi
I have no idea what was done to this engine, it was rebuilt in 1991 and has been driven appr 10K miles and i would have thought any major problems would have been taken care of.
Semper Fi
[Re: GOLDMYN]
#658444
04/02/10 01:17 AM
04/02/10 01:17 AM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
CLAMP ON AMP PROBE I've used them on 240-440 phase AC motors and starter relays but never used one on 12v DC. But if you have a probe, clamp it over the battery to starter cable and watch it as the engine heats up. If the AMP reading changes as the motor heats up, it's either the starter or cable or both. http://www.sears.com/shc/s/p_10153_12605...00001&aff=Y
[Re: JonC]
#658448
04/02/10 07:36 AM
04/02/10 07:36 AM
GOLDMYN
Kenosha, Wi
I went back over the receipts I got with the car and there is a pattern, They replaced 4 starters, over the course of 10 years, it does show that the problem existed for awhile.As far as bad voltage regulator, the battery is charging because when it cools down it cranks and starts fine. 2. wrong vacumn advance hook up?, its a 2bl carb, can only hook up to one port? any more thoughts?..thanks again
Semper Fi
[Re: GOLDMYN]
#658453
04/02/10 12:54 PM
04/02/10 12:54 PM
DaytonaTurbo
Manitoba, Canada
I'm sorry but that's exactly what mine did when the v-reg crapped out. Would fire up perfect when cold, I drove it to an empty parking lot to do some WOT launches to dial in the carb a bit. Did that for a while and turned it off. Fired it up a minute later and it cranked over slow. Some more launches and I turned it off and tried to fire it up again 1 minute later. Got nothing. Rur... click. Let it cool down 30 minutes and it fired back up again just fine. Did the same thing after taking it for a long drive around town. Go cruising around for a half hour, come home, stop in the driveway, key off and it wouldn't crank over. Let it cool 1/2 hour come back outside and it cranked over perfect.
Changed the voltage reg and problem gone. Not saying this is your problem, but I highly suggest bringing along a spare charged battery and a set of booster cables just to verify this to not be a problem. Takes more juice to turn over a hot motor than a cold one, so it's possible your battery is only charging marginally like mine was.
[Re: DaytonaTurbo]
#658454
04/02/10 01:02 PM
04/02/10 01:02 PM
GOLDMYN
Kenosha, Wi
thank-you, any chance it might be the starter relay on the firewall?
Semper Fi
