Replacing the input shaft cover - power stearing gear #658411
04/01/10 07:19 PM
04/01/10 07:19 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
OK in trying to get the roll pin out; I cracked the input shaft cover of the steering gear (power steering)... - the housing that screws into the input (steering col side).
I have a number of other housings, can I just take one off and install it?
I assume you have to adjust the backlash or something...
I think I am done before I break anything else...
Thanks in advance...
Re: Replacing the input shaft cover - power stearing gear [Re: 6T6Cuda] #658412
04/01/10 07:30 PM
04/01/10 07:30 PM
IMGTX Offline
IMGTX  Offline
I would think with that much stress the shaft may be bent too.
I would go with the whole box myself.
Otherwise it should be a simple swap but there is going to be a seal. Napa sells the seal kit with all the seals you would need to rebuild it.
