Re: Timing chain replacement on a Big Block 400
[Re: RapidRobert]
#657668
04/05/10 10:32 PM
04/05/10 10:32 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Like Robert said, when putting the seal in, don't just peck on it, get it started and just knock in. Don't mess around with it, you'll get it cocked. A poor boys way of putting the balancer back on is to use a crank bolt and washer from a small block. that will pull it up enough to use the big block bolt to finish pulling it in. If you have a impact wrench good, if not use a 1/2" drive ratcht and screw a couple of bolts into the balancer and use a pry bar to keep it from turning while you tighten it up. Good luck, and this is the way you learn. "Them that can, do. Them that can't, teach."
[Re: buildanother]
#657677
04/12/10 10:15 PM
04/12/10 10:15 PM
Posts: 10,208 Someplace you aren't
SomeCarGuy
You will have some slack, not a lot, but some. Only one I know of that was SUPER tight was a Rollmaster I had one time.
Don't be surprised if that STP filter is just a repackaged Fram.
I want my fair share
[Re: SomeCarGuy]
#657678
04/12/10 10:31 PM
04/12/10 10:31 PM
RapidRobert
That's a oe replacement morse "silent" type and will have some slack even when new. If this is a low perf daily driver plus the fact that you already have it I'd put it together & get back on the road.
