72 Duster gas pedal #657547
03/31/10 10:53 PM
03/31/10 10:53 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Does anyone have a pic of the throttle pedal assembly? I was running the car and the throttle stuck wide open. Is there a return spring on the pedal itself. The carb seemed quite free and it omly stuck when I used the gas pedal, not when I reved it by hand.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: 72 Duster gas pedal [Re: reno340] #657548
03/31/10 11:03 PM
03/31/10 11:03 PM
just the return spring forward from the carb horizontle throttle pin to the bracket on the dr front of the intake. Take the throttle cable off of the inside edge of this horizontle pin & see if the cable/pedal is free.
Re: 72 Duster gas pedal [Re: reno340] #657549
04/01/10 05:49 AM
04/01/10 05:49 AM
Newmarket, Ontario. CANAD
mopargord Offline
super street
mopargord  Offline
super street
It has been a long time, but,when I had my first 70 Duster I discovered there was a raised "bump" in the floorpan just in the area of the "floating" gas pedal travel and when you "punched" the pedal hard enough it would catch the lower edge of the pedal on that "hump" and would jam in "w.o.t." I do not know if the floor pan profile on your 72 is the same as the 70 but it might be worth checking out.
I cured this by cutting about 1/2 inch off the bottom of the pedal.Hope this info helps, good luck.
