69 Charger 383 4 speed w/ cruise? #657325
03/31/10 08:11 PM
03/31/10 08:11 PM
mopar heaven
rustbucket Offline OP
mopar heaven
I was looking at a charger the other day that was an original 383 4speed. I was looking over the engine compartment and noticed two factory mounting screws exactly where the faxctory cruise control would mount. I then looked in the trunk and there it was..... acomplete cruise control with the correct mounting bracket which is unique to B-bodies. Could you get cruise with a 4 speed??
Re: 69 Charger 383 4 speed w/ cruise? [Re: rustbucket] #657326
03/31/10 11:33 PM
03/31/10 11:33 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No. Automatic transmission and power brakes required.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
