short plugs #657073
03/31/10 02:31 PM
03/31/10 02:31 PM
South Carolina, United States
carolinacuda Offline OP
Hey fellas. I asked this quest earlier but no response so i thaught id ask again. I have a 440 with indy heads and hooker headers. I have a couple of plugs that are close to the header so i thaught i would try short plugs. Can i mix these with other plugs and be ok or should i use a whole set of shorty's? I only need 2 of them. Is there any performance differences between them and a standard length plug?
Re: short plugs [Re: carolinacuda] #657074
04/01/10 11:50 AM
04/01/10 11:50 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im curious also. I have some getting really close.
10.8 to 1 aluminum heads small block.
Kasey
Re: short plugs [Re: Moparnut426] #657075
04/01/10 07:05 PM
04/01/10 07:05 PM
UK
602heavy Offline
602heavy  Offline
UK
As long as heat range is the same as the others you should be fine , then again some cylinders would fair better with higher/lower heat range , some short plugs are the non projected type ,i would change them all out for the same type.
