original carter *AVS* good or bad? #657025
03/31/10 01:51 PM
03/31/10 01:51 PM
North Central Florida
E
eightlitermopar Offline OP
E
Spring is in the air, I have to start working on something (even though it is snowing today)
I currently have a 71 RR with a 383, and it has the beloved eddelbrock 750 cfm on it.
I "borrowed" a 600 cfm eddy unit from my dad, but when he needed it back, I switched back to the 750.
I was amazed at how much better the car ran with the 600.
Anyway, I have an original carter carb off a 1969 chrysler station wagon with a 440 in my shed. It ran when I originally got the motor.
I will get the stamping number later. Would I benefit from cleaning/gasketing the carb and throwing it on the roadrunner? Or am I just putting my effort in the wrong place.
I am on a tight income as the new baby is due in 2 months, but any input would be greatly appreciated.
Again, I am on a tight budget but would like to work with what I have.
Thanks for the info, sorry for the long post
eight
Mopar or no car
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657026
03/31/10 04:06 PM
03/31/10 04:06 PM
E
E
Ok changed the original post
It is a CARTER AVS carb 4968 S
Supposidly from a 1971 440 with an automatic.
Would it be worth my time to redo this carb or stick with the eddy 750?
Any thoughts?
Thanks-eight
Mopar or no car
Re: original carter afb good or bad? [Re: eightlitermopar] #657027
03/31/10 04:14 PM
03/31/10 04:14 PM
It'll work good for you as it is the largest CFM oe AFB & is listed as iirc 750 cfm but is nowhere close to that but do check the play in the primary throttle shaft as it's 40 + yrs old & no telling how many miles it has seen. NAPA kits are reportedly a slight better than most though none are worth writing home about and w 99% of oe AFB's having 2 step rods/matching jets, an eddy strip kit will work if you want to play (a few motorhome AFB's had 3 step (AVS type) rods/jets) w the domed cap). I have a NAPA AVS kit ordered and it is $28.09 and you can tap the boss on the other side to make it a dual feed and there was a thread yesterday about subbing in an eddy? viton accelerator pump for the oe leather so I'd look that thread up & order one
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657028
03/31/10 04:27 PM
03/31/10 04:27 PM
It is a CARTER AVS Any thoughts?
1st was the 750 eddy acting up or was it just larger cfm than needed & that's why the eddy 600 worked better? All oe AVS's were emission carbs and I understand that you can sub in AFB/eddy 2 step rods and the attending 2 step type jets to play with them. On the cheap the 30 dollar kit and the brass floats would still be good and several $$$ for a viton AP and you could get by w spraying the inside of the carb passages out w a can or 2 of starting fluid. Sounds like you are wanting to get away from that eddy 750
Re: original carter *AVS* good or bad? [Re: RapidRobert] #657029
03/31/10 05:13 PM
03/31/10 05:13 PM
E
E
[quote Sounds like you are wanting to get away from that eddy 750
It works ok, starts right up...but I can tell it runs rich even when it's not supposed to.
Even at idle, I'll get it cleaned up...then it lacks power...The 600 was just better...but it did fall on it's face at high revs.
I could go on and on....but just toying with what I have. I don't know anything about these original carter carbs and was just looking at my options. Any links or direction into these carbs would be helpful.
eight
Mopar or no car
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657030
03/31/10 05:31 PM
03/31/10 05:31 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The orignal carter will be a better carb then the 750 eddy. I like the eddy AVS carbs but the 750's are nothing but trouble. Clean up the carter, get a kit and freshen it up. See what that 600 had for jets. Might be a good place to start tuning that carter for your motor.
Re: original carter *AVS* good or bad? [Re: Dougsmopars] #657031
03/31/10 06:23 PM
03/31/10 06:23 PM
What Doug said, when you take the top off of it you'll see how simple it is and unloosen/remove the fuel inlet fitting 1st before you take the screws loose/top off.
Re: original carter *AVS* good or bad? [Re: Dougsmopars] #657032
03/31/10 07:58 PM
03/31/10 07:58 PM
E
E
Ok, stupid question here... So can I use the same rods/jets from an edelbrock tune kit or do I get this specifically for older carters somewhere else. I have tuned edelbrocks for years so how they work is not too far out for me to understand.
thanks!
eight
Mopar or no car
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657033
03/31/10 08:25 PM
03/31/10 08:25 PM
That is not a stupid Q at all. I have not done it (yet) but I understand the Eddy 2 step rods/jets will work in the oe AFB's and in the oe AVS's but in the oe AVS case, eddy pri jets must be used (they're made for the 2 step rods as opposed to the taller oe AVS pri jets for the 3 step oe rods) along w an AFB flat cover(s)(2). But I think there are several eddy strip kits so I dont know if you only need to get the kit that has close to the same dia/orifice rods/jets as the oe AFB/AVS ones originally in use or if something else is different but I dont know what it could be. I've compared eddy/oe and the only diff I see (other than dia's) is the transition is at a slightly different point along the length of the rod
Re: original carter *AVS* good or bad? [Re: RapidRobert] #657034
03/31/10 08:44 PM
03/31/10 08:44 PM
E
E
Interesting....
does anyone sell the kits with rods/jets specifically for the old carter carbs? how was this done back in the day?
thanks!!
Mopar or no car
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657035
03/31/10 09:04 PM
03/31/10 09:04 PM
"back in the day" there was 1 strip kit for AFB's and 1 for AVS's and they came with a multitude of rods/jets/needles/seats as compared to the meager offerings in the eddy kits (or at least the one (1487) for my eddy 1406 (600 elec choke)which had a few of each. My sheet lists 6 different strip kits (eddy calls them calibration kits) for the performer series carbs. carb-kit: 1403/1404-#1486. 1405-1479. 1406-1487. 1409-1488. 1407/10/12/13-1480. 1411-1489 with a total of 16 different pairs of jets available and 19 pairs of rods available which is most likely the total in all of the above kits combined ranging from a .077" to a .119" on the jets and .062"/.052" at the top of the chart to .075"/.047" (19) lower at the bottom of the list but the other day at the Rocky manginelli swap meet I bought a pair of eddy (oe AFB/AVS maybe) .120" jets so there's more to the story but you (now) know what I know
Re: original carter *AVS* good or bad? [Re: RapidRobert] #657036
03/31/10 09:57 PM
03/31/10 09:57 PM
E
E
I agree with the meager offerings of edelbrock calibration kits. Because of my elevation and use, I actually had to buy two kits at one time to get all the right rods/jets matched right.
I am interested in this carter thing though, I will keep looking.
eight
Mopar or no car
Re: original carter *AVS* good or bad? [Re: eightlitermopar] #657037
03/31/10 10:02 PM
03/31/10 10:02 PM
Dougsmopars Offline
Dougsmopars  Offline
the worst part is if you look at the tuning guide half of the rods and jets don't come in that kit. They want you to fork over another 30 bucks to get a different kit.
Re: original carter *AVS* good or bad? [Re: Dougsmopars] #657038
03/31/10 10:28 PM
03/31/10 10:28 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
It would be worth trying the AVS. A great carb. I think you may need to use the flat caps off the AFB eddy to be able to run the 2 step rods.
I want my fair share
