UPDATE intake manifold recomendation #656971
03/31/10 01:47 PM
03/31/10 01:47 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Have a stock RR HP 383 all stock engine and want to ditch my iron DP manifold but not sure what to get?? DP or SP aluminum manifold ... could someone possibly explain the dif between the 2 and what would be the best for a 69 383 (std bore flat top HP pistons W/ 3.23 rear) no racing , just cruizing the coast line
Re: intake manifold recomendation [Re: ngpSatellite] #656972
03/31/10 01:50 PM
03/31/10 01:50 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Get the dual plane.
Re: intake manifold recomendation [Re: Neil] #656973
03/31/10 01:55 PM
03/31/10 01:55 PM
North Central Florida
E
eightlitermopar Offline
E
Dual plane all the way. I made the same mistake almost 10 years ago.
Roadrunner, mild (emphasis on mild) 440 with a torque cam. Cast iron intake, exhaust manifolds, and a holley dp carb.
I switched to a 750 edlebrock (sold the holley) and when to a Mopar M1 single plane high rise manifold.
It never ran the same again. No low end torque, killed drivability. My embarassing 15 second quarter mile decreased to an even more embarassing 17. It was quite a learning experience. Go with a dual plane.
eight
Mopar or no car
Re: intake manifold recomendation [Re: eightlitermopar] #656974
03/31/10 02:00 PM
03/31/10 02:00 PM
own private Idaho
N
N
own private Idaho
thanks ....I was just about to pull the trigger on a SP what make and model is the best aluminum DP...
Re: intake manifold recomendation [Re: ngpSatellite] #656975
03/31/10 02:05 PM
03/31/10 02:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Get an edlebrock performer or performer rpm intake.
Re: intake manifold recomendation [Re: ngpSatellite] #656976
03/31/10 02:07 PM
03/31/10 02:07 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think I can say that pretty much without question: The Edelbrock Performer RPM is going to be your best option. Its a high-rise dual plane that works real good on stock to mild street / strip motors. Only issue might be hood clearance (???).
Re: intake manifold recomendation [Re: Neil] #656977
03/31/10 02:08 PM
03/31/10 02:08 PM
own private Idaho
N
N
own private Idaho
Thanks Gents!!
Re: intake manifold recomendation [Re: ngpSatellite] #656978
03/31/10 02:08 PM
03/31/10 02:08 PM
E
E
Some basic aftermarket dual plane manifolds are basically the same as your cast iron intake, only lighter aluminum.
Edelbrock performer or performer RPM (this sits slightly higher than stock) would be my vote for a stock motor.
Or just my , since there won't much be a noticeable difference. Just put a 4 hole spacer between your iron intake and the carb for some added throttle response and some power gain?
anyway you go, good luck. SP would be a step in the wrong direcetion though.
eight
Mopar or no car
Re: intake manifold recomendation [Re: eightlitermopar] #656979
03/31/10 02:22 PM
03/31/10 02:22 PM
the single plane Holley Street Dominator was the BEST dual plane intake ever made
Re: intake manifold recomendation #656980
03/31/10 03:10 PM
03/31/10 03:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Look on ebay and the classifieds here for a used edelbrock DP4B intake. For stock heads it's all the flow you need. You won't gain anything except less hood clearance if you go with the performer rpm over the dp4b.
The holley SD is a good intake, but not for a stock 383 with 3.23 gears.
Re: intake manifold recomendation [Re: DaytonaTurbo] #656981
03/31/10 03:28 PM
03/31/10 03:28 PM
whatever you say..
Re: intake manifold recomendation [Re: DaytonaTurbo] #656982
03/31/10 04:42 PM
03/31/10 04:42 PM
Puyallup, WA
Puyallup, WA
Agreed, but we have all been through this, haven't we??? First its an intake. Next He'll look to buy a Holley carb. Then he might as well add headers. Hey, next let's take a stab at a Cam-swap. Then, how about some deeper gears.... I can't be the only one that's been through this!
So with that in mind, The RPM is an intake that will support his desires all the way up to and including an 11-second stroker motor. Since it also works well on stock-ish motors, might as well go straight there, now.
Re: intake manifold recomendation [Re: StealthWedge67] #656983
03/31/10 05:03 PM
03/31/10 05:03 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The RPM will make a little more power then the performer but check your hood clearence first. Unless your going to cut the hood for a scoop anyways then it doesn't matter.
Re: intake manifold recomendation [Re: ngpSatellite] #656984
03/31/10 05:04 PM
03/31/10 05:04 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
NO racing ? .. just cruizin' ??
Get an old-school Eddy Streetmaster. Decent performance and good MPG. To get BESTer MPG ...add a TQ carb.
Re: intake manifold recomendation [Re: Dougsmopars] #656985
04/01/10 01:13 PM
04/01/10 01:13 PM
own private Idaho
N
N
own private Idaho
the main reason I'm switching manifolds is that I still have alittle bit of a restart issue when I turn off the engine (gas station for example) and it is hard to restart (alittle embarrassing for a mopar guy )so I was thinking an aluminum manifold would conduct less heat to the carb... when I'm shutting the car off the temp is around 170 to 190 max so the car is not running hot.... I also have a spacer (1/2.. 4 hole phenalic)on it now. (edel 750)
Re: intake manifold recomendation [Re: ngpSatellite] #656986
04/01/10 01:19 PM
04/01/10 01:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What makes you think it's a heat related problem?
Re: intake manifold recomendation [Re: stumpy] #656987
04/01/10 01:22 PM
04/01/10 01:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Warm engine try holding the gas pedal to the floor right away when you start to turn the engine over. Lots of times helps for quicker starting by unloading any loaded up gas accumulation.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: intake manifold recomendation [Re: StealthWedge67] #656988
04/01/10 01:22 PM
04/01/10 01:22 PM
Manitoba, Canada
Manitoba, Canada
True, however for as long as he's running bone stock heads, he will never see a noticable increase in power with the rpm over the dp4b. Heads are the bottle neck at that point. The 383 intake shootout hot rod mag did showed exactly that, I think the dp4b even put out a few more ft-lbs(and at a lower rpm) than the rpm when tested on a stock headed 383 with a decent cam. I think the rpm was good for 5hp or something insignificantly like that. I suggest the dp4b because he can bolt it on and go, no issues with needing drop base air cleaners is a plus.
Re: intake manifold recomendation [Re: stumpy] #656989
04/01/10 03:34 PM
04/01/10 03:34 PM
own private Idaho
N
N
own private Idaho
when I start it cold it starts up fine and when I have a quick stop to make (10 min or so) the engine seems to take alot of cranking to start back up....(eng temp seems alittle high, plus enging compartment feels hot) and alot of the times I'll open the hood and take off the air filter to get it to resart because I don't want to wind down the battery
Re: intake manifold recomendation [Re: ngpSatellite] #656990
04/01/10 04:42 PM
04/01/10 04:42 PM
Dougsmopars Offline
Dougsmopars  Offline
Sounds like an over heat problem to me. Lose the phelic spacer. Get the eddy thermal spacer. It's abut a 1/2 to a 1/2 inch thick. It's an insulator gasket.Also check your water flow. Excessive engine compartment heat soiunds like steam pockets in the heads.
