68 dart proportioning valve
#655348
03/29/10 09:03 PM
03/29/10 09:03 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
so, im trying to figure out if the proportioning valve i have is the correct one for my kelsey hayes disc brake setup. how do i tell the normal valves apart from a disc brake setup? if it matters, it is an early production 68 Dart GTS with factory discs. thanks for the help!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 68 dart proportioning valve
[Re: GTSDart340]
#655349
03/29/10 11:33 PM
03/29/10 11:33 PM
GTSDart340
Laveen, Arizona
i guess a better question is does someone have a diagram of how the brake lines for a 68 dart with discs is supposed to be? thanks!
[Re: Pntastar69]
#655352
03/31/10 10:46 PM
03/31/10 10:46 PM
GTSDart340
Laveen, Arizona
thanks for the pictures... so, is it possible that my dart didnt use a prop valve? i see where the valve is on your dart, but my dart has a solid brake line all the way up to where the saftey switch is. interesting...
[Re: Pntastar69]
#655355
04/07/10 11:15 AM
04/07/10 11:15 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Here is a 69 Dart w/factory disks up front.
The above picture looks very similar to a 69 B body with discs - where at the line running to the back brakes has an inline valve, possibly an additional KH manual prop valve just for the rear lines. For a 70 and up A body disc brake car there was no rear inline prop valve - there was one combination prop / distribution valve. 70-75 disc brake cars use a prop valve like the one in the attached pic. In 75 they started phasing in a different KH prop valve made of cast iron. I've seen these cast iron prop valves on pre-75 B bodies. In 78-79 they moved to a brass style of the cast iron prop valve. I've seen these on F and B bodies.
Here's a 70 - 75 A body disc brake prop valve...I have seen some of the valves without the hex shaped 'spacer' at the top of the valve.
[Re: GODSCOUNTRY340]
#655359
04/10/10 01:31 AM
04/10/10 01:31 AM
GTSDart340
Laveen, Arizona
so thats the only valve your GTS has? im still just trying to figure out what i need to get for my car. thanks!!
[Re: GTSDart340]
#655360
04/10/10 06:52 PM
04/10/10 06:52 PM
Posts: 2,535 God's Country Maryland
GODSCOUNTRY340
No, there's another valve to the rear brakes. Follow the line to the rear in the picture for the light colored car above and you'll notice the smaller valve about 14" back. This one actually regulates the pressure for the rear drums.
