Re: Not turn over [Re: j3wbagell] #654964
03/31/10 02:01 PM
03/31/10 02:01 PM
North Central Florida
E
eightlitermopar Offline
E
will that evaporate?
Probably not, but all that gas "might" wash down all your oil from your cylinders and piston rings.
take the plugs out, DISCONNECT YOUR COIL, and get the gas out.
eight
Mopar or no car
Re: Not turn over [Re: eightlitermopar] #654965
03/31/10 05:05 PM
03/31/10 05:05 PM
Cen Fla
j3wbagell Offline OP
Cen Fla
eight
will i have to redo my timing?
Re: Not turn over [Re: j3wbagell] #654966
03/31/10 05:06 PM
03/31/10 05:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No you aren't changing that. Just pull the coil wire out of the coil or the center post of the distributor
Re: Not turn over [Re: stumpy] #654967
04/01/10 08:27 AM
04/01/10 08:27 AM
scratchnfotraction Offline
remove all spark plugs and pull coil wire off coil and dist
crank engine over,if its full of any liqid it will shoot it out the plug holes
do not stand at the sides of engine bay when cranking it over
cyls cleard it should fire up and run again
