What size is the bolt that holds lower front Shock #654822
03/29/10 03:10 PM
03/29/10 03:10 PM
Anonymous OP
Anonymous OP
need to find out what size is the bolt that holds the lower shock into the control arm on a 1965 plymouth Belvedere?
thanks
Re: What size is the bolt that holds lower front Shock #654823
03/29/10 06:01 PM
03/29/10 06:01 PM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
Re: What size is the bolt that holds lower front Shock #654824
03/29/10 09:29 PM
03/29/10 09:29 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
7/16 X 2-1/4 or 2-1/2 I see both lengths and both fine or coarse thread, self locking nut, without lock washer usually. 2-1/4 bolt will extend through the nut about 1/4 inch.
