68 Cuda Repaint/4-link/Quarters NEW PICS
#654705
03/29/10 12:38 PM
03/29/10 12:38 PM
Posts: 1,169 MI
68shifter
MI
I thought I might post a few of mine. It's a 68 340 4 speed car I have been racing the last 7-8 years. Last fall we had some bad track conditions and the car got loose coming into contact with a mustang and really hurting both my car and his. Currently it is a 440 with stock crank and rods and a GF4A G-force 4 speed. Usually ran in the 10.40's with the old SS and/or cal tracs. The accident pushed me to replace the rear trunk/quarters that were rotted pretty good. Not done yet but a work in progress. Limited funds and limited time. Thanks and don't rip me too bad.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
Re: 68 Cuda Repaint/4-link/Quarters
[Re: 68shifter]
#654706
03/29/10 12:40 PM
03/29/10 12:40 PM
Posts: 1,169 MI
68shifter
MI
The batterd side and heres some of the rust.
64' Savoy (4 speed)
[Re: 68shifter]
#654708
03/29/10 12:41 PM
03/29/10 12:41 PM
Posts: 1,169 MI
68shifter
MI
one with the floor removed - for roughing everything together.
64' Savoy (4 speed)
[Re: 68shifter]
#654709
03/29/10 12:43 PM
03/29/10 12:43 PM
Posts: 1,169 MI
68shifter
MI
Both rear quarters were a mess. The car was painted in the late 90's and my body guy opened the quarters a couple of times and finally settled on making a lip out of pieces of metal, bondo, and steel wool. Needless to say it broke out and cracked often. I plan on doing the paint, as I am doing everything this time.
64' Savoy (4 speed)
[Re: 68shifter]
#654710
03/29/10 12:45 PM
03/29/10 12:45 PM
Posts: 1,169 MI
68shifter
MI
This is the front. Old Mr. fiberglass fender broke all to death so I removed it. When we hit I swung around and bounced off his car breaking my fender, buckling the rear fenders on both sides and buckling the trunk pan.
64' Savoy (4 speed)
[Re: 68shifter]
#654712
03/29/10 12:47 PM
03/29/10 12:47 PM
Posts: 1,169 MI
68shifter
MI
I bought an S&W four link kit along with alot of stuff from them. Pics are somewhat in stages as I didnt take them at each step just as I went.
64' Savoy (4 speed)
[Re: 68shifter]
#654713
03/29/10 12:48 PM
03/29/10 12:48 PM
Posts: 1,169 MI
68shifter
MI
This was a nice productive weekend.
64' Savoy (4 speed)
[Re: 68shifter]
#654714
03/29/10 12:51 PM
03/29/10 12:51 PM
Posts: 1,169 MI
68shifter
MI
Rear quarters were from Sherman and associates. Really didnt go to bad. I cut the old ones about an 1 from the top line and stuff really went well. The rocker for passenger side was from them as well. What a piece of garbage. I spent as much time cutting it and making it fit as well as putting a taper in it to get it the way it should be.
64' Savoy (4 speed)
[Re: 68shifter]
#654715
03/29/10 12:53 PM
03/29/10 12:53 PM
Posts: 1,169 MI
68shifter
MI
Welded up. One thing I didnt expect was the outer edge dropped some even though the thing was braced well, so it took about 2-3 building a wooden jig to get it back right. Learn as you go sometimes.
64' Savoy (4 speed)
[Re: magnumcharger]
#654717
03/29/10 06:15 PM
03/29/10 06:15 PM
Posts: 16,474 On the run…
BloFish
On the run…
Are you building a small tire car?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#654718
03/29/10 07:20 PM
03/29/10 07:20 PM
Posts: 1,169 MI
68shifter
MI
It is going to be a 32x14 tire. I'll post more pics tomorrow of that. The fram is S&W and when all said and done it leaves about 2" of clearance inside and outside of the tire to frame and wheel well. I did open the wheel well about 7 inches. I waited til' they were on that way everything was solid, also I didnt get the tires until I was welding on the second quarter. I have more pics of that stuff as well as wheels etc. Talk about slow. Thanks.
64' Savoy (4 speed)
[Re: 68shifter]
#654719
03/29/10 07:24 PM
03/29/10 07:24 PM
I like it! looks good so far. Keep the pics coming.
[Re: ]
#654720
03/30/10 02:05 PM
03/30/10 02:05 PM
Posts: 1,169 MI
68shifter
MI
another, getting closer to paint.
64' Savoy (4 speed)
[Re: 68shifter]
#654721
03/30/10 02:06 PM
03/30/10 02:06 PM
Posts: 1,169 MI
68shifter
MI
Got the better half to help sand and spray bomb the frame rails so they didnt rust with all the work.
64' Savoy (4 speed)
[Re: 68shifter]
#654722
03/30/10 02:07 PM
03/30/10 02:07 PM
Posts: 1,169 MI
68shifter
MI
I filled the exhaust cutouts and straightened the rear roll pan.
64' Savoy (4 speed)
[Re: 68shifter]
#654726
03/30/10 02:11 PM
03/30/10 02:11 PM
Posts: 1,169 MI
68shifter
MI
Thats the car largely in primer. I have block sanded it three times since then and still have more to go.
64' Savoy (4 speed)
[Re: 68shifter]
#654727
03/30/10 02:14 PM
03/30/10 02:14 PM
Posts: 1,169 MI
68shifter
MI
I shot the door jambs trunk and engine bay the blue it'll get before finish sanding. Its getting a custom PPG blue thats pretty close to Intense Blue Pearl but it will get shot over a silver base with more pearl added in the primary two clear coats and topped by two straight clear coats to wet sand and protect. So far I have done every bit of the work myself. Its not perfect but is coming out pretty nice.
64' Savoy (4 speed)
[Re: 68shifter]
#654728
03/30/10 02:17 PM
03/30/10 02:17 PM
Posts: 1,169 MI
68shifter
MI
This is the last pic I have so far. The wells have been cut for the tire, but NOT finished yet. I have been working on a 57 Chevy for a body guy to get his car going. In trade I get to use a booth for a weekend to actually spray the car in. I'll try to post some more this weekend of the engine in the car and closer to finished wheel wells - since hopefully his 56 Sedan will be done so I have some time. Thanks again.
64' Savoy (4 speed)
Re: 68 Cuda Repaint/4-link/Quarters/New pics
[Re: 68shifter]
#654733
04/08/10 09:32 PM
04/08/10 09:32 PM
Posts: 1,169 MI
68shifter
MI
Front end put closer together and fitting.
64' Savoy (4 speed)
Re: 68 Cuda Repaint/4-link/Quarters NEW PICS
[Re: 68shifter]
#654735
05/20/10 10:17 PM
05/20/10 10:17 PM
Posts: 1,169 MI
68shifter
MI
Finally got the rear axles and everything mocked up and tacked together. Still working on the body and getting money for more parts. Hoping by Memorial day it will be ready for paint. The end goal is to hopefully make the Martin Chrysler Classic in July. We'll see.
64' Savoy (4 speed)
[Re: 68shifter]
#654736
05/20/10 10:19 PM
05/20/10 10:19 PM
Posts: 1,169 MI
68shifter
MI
Another of the side. I really like the stance now.
64' Savoy (4 speed)
[Re: 68shifter]
#654737
05/20/10 10:20 PM
05/20/10 10:20 PM
Posts: 1,169 MI
68shifter
MI
One of the motor. It's a little dirty. I ordered some new Firecore wires for it, and I have to do something with the purple throttle bracket yet too.
64' Savoy (4 speed)
[Re: 68shifter]
#654738
05/20/10 10:22 PM
05/20/10 10:22 PM
Looks really good! I agree with you on the stance.
[Re: plumcrazy704406]
#654741
05/28/10 11:31 AM
05/28/10 11:31 AM
Posts: 604 TN
1DGEMAN
TN
I like your work. I am in the planning stages for a 67 Barracuda 4sp for Nostalgia Super Stock. What brand of front fenders and hood are you using? Any fitment issues? What brand of headers any tubes through the inner fender panels? Being an old Stock eliminator guy I am planning on using Cal Tracs for the rear suspension. I just want to run high 9's.I don't think it will be a problem with 512 stroker and a light car.
Real Men shift for themselves
[Re: 1DGEMAN]
#654742
05/30/10 07:03 PM
05/30/10 07:03 PM
Posts: 1,169 MI
68shifter
MI
Yeah me and the competitior were fine. Would have much rather it just been my car. That 67 Nostalgia SS sounds cool. I have AAR front glass that fit really well with only a few adjustments and filler here and there. The headers are TTI and what a pain in the A! I didnt want tubes in the fenders so I did the under chassis TTI's and had to dent them for the starter, the torsion bars and my drag link is very close. I hear the newer versions fit better. Keep us updated on your car. A word of advice on the sticks/clutches. Spend whatever you need to at the outset to get a good clutch. I fought for years trying to use S/S clutches and finally went to a sintered iron adjustable. Tim Hyatt is an awesome guy to talk to and so is Rob Youngblood. Everything in them anymore revolves around the clutch. I'll post some more pics soon. Somehow it's 90* in MI and my fat butt is sweating to death sanding and welding all weekend.
64' Savoy (4 speed)
Re: 68 Cuda Repaint/4-link/Quarters NEW PICS #2
[Re: 68shifter]
#654744
06/03/10 08:56 PM
06/03/10 08:56 PM
Posts: 1,169 MI
68shifter
MI
nuther. I'm trying to figure out photobucket so they all load at once. We'll see.
64' Savoy (4 speed)
[Re: 68shifter]
#654746
06/03/10 09:13 PM
06/03/10 09:13 PM
Posts: 1,169 MI
68shifter
MI
I thought I'd have it in solid primer and wet sanded but everyone was closed for the holiday so it'll have to wait for another weekend or two. I have aluminum on order for the floor and will finish that and all the plumbing once paint is done. I'm trying to figure out what front wheels I want to run. Any suggestions out there? Weld, Gibson, American Racing. Thanks all.
64' Savoy (4 speed)
[Re: 68shifter]
#654747
06/04/10 10:40 AM
06/04/10 10:40 AM
Awesome welding job Andre,getting closer. I like the weld drag lights myself.
68 Cuda Repaint/4-link/Quarters Floor Update
[Re: 68shifter]
#654749
06/19/10 08:44 PM
06/19/10 08:44 PM
Posts: 1,169 MI
68shifter
MI
64' Savoy (4 speed)
Re: 68 Cuda Repaint/4-link/Quarters NEW PICS#3 Paint!
[Re: 68shifter]
#654750
06/20/10 02:00 AM
06/20/10 02:00 AM
Awesome! Looks really good.
Re: 68 Cuda Repaint/4-link/Quarters Update#3
[Re: Mopar Grandpa]
#654752
08/09/10 07:38 PM
08/09/10 07:38 PM
Posts: 1,169 MI
68shifter
MI
64' Savoy (4 speed)
[Re: 68shifter]
#654753
08/09/10 11:41 PM
08/09/10 11:41 PM
Well it's certainly a lot nicer than what I am doing, now I'm jealous. Again.... you are doing an awesome job.
Re: 68 Cuda Repaint/4-link/Quarters Update #3
[Re: ]
#654754
08/10/10 12:04 AM
08/10/10 12:04 AM
Posts: 1,169 MI
68shifter
MI
Thanks. But I'll tell yah, you made the smart move with steel. You can't touch the aluminum without scratching it or putting some kind of dent in it. I think this winter I'm going to repaint the interior black because of all the scratches I have in it from fitting. And I might paint all the aluminum some sort of silver or gray because of the scratches - and it'll never stay remotely clean.
64' Savoy (4 speed)
[Re: 68shifter]
#654756
09/22/10 11:12 PM
09/22/10 11:12 PM
[Re: joewhite440]
#654759
09/23/10 10:04 PM
09/23/10 10:04 PM
Posts: 1,169 MI
68shifter
MI
Thanks for the input guys. Heres a couple more pics. Going to get the tires mounted on the wheels tomorrow, and hopefully some pics of it rolling and stopping! this weekend. Now if a couple more duramax's will puke injectors or CP3's I can afford to buy the the two pieces of trim for the deck lid and have the back looking good. Andre
64' Savoy (4 speed)
[Re: 68shifter]
#654760
09/24/10 12:47 AM
09/24/10 12:47 AM
What size welder did you use on the rear housing and the brackets and what size springs on the rear did you use ( lbs )?
[Re: ]
#654761
09/25/10 12:31 AM
09/25/10 12:31 AM
Posts: 1,169 MI
68shifter
MI
For most of the welding I have an older Miller 175, probably 17/18 years old. If I recall correctly its rated to 1/2-5/8 and it has welded alot of truck (semi dump trucks, roll'offs etc.) Its a great welder, for small stuff I'll put .023 wire in it, and for the chassis stuff some .035 and go to town. It doesnt have all the bells and whistles, but comfort I think is a big part. The rear springs are 110lb. Car roughly 3000lbs I'm guessing. I talked with Bickel about them alot and he recommended a lighter spring even though I could have went heavier. Lighter springs in a heavier car can store more energy while maintaining ride height and respond quicker. The only down side is they will wear out faster but springs arent too expensive. A heavier spring will last longer but in all honesty if springs cause me to loose a couple hundreths, who cares. Sorry so long. Andre
64' Savoy (4 speed)
Re: 68 Cuda Repaint/4-link/Race results
[Re: BloFish]
#654765
10/10/10 12:17 AM
10/10/10 12:17 AM
Posts: 1,169 MI
68shifter
MI
Well wasnt too bad for the first time out. I just wanted to do T&T but turns out it was a make-up race with the biggest modified field all season 137 cars....wheeewww. First run burnout was kinda crappy, and light was late. Dump the clutch and front raised good but I felt it move to the right a touch so I got out of it enough to get it straight and then back in. It went [Email]10.64@128[/Email] with a 1.47 60'. So on run #2 I tightened compression on RR shock 3 clicks and took one turn out of rebound on left side. Better burnout, and weather much hotter. Dump the clutch and the front raised really well but still floated to the right but only just a touch. Again I backed out of it, and then ran it through to a [Email]10.48@130.68[/Email] the 60' was 1.43. 2mph better than previous best. Plus the car was raisng the front 3 foot or better. I'm pretty happy all in all, shows me theres alot more there. I only made two runs because of count and time, plus I didnt want to do eliminations til' it was arrow straight. I'm going to put some pre-load in the r-upper bar and try again next weekend. Good to be racing again. Oh the pic of a redlight.... 0.003 red
64' Savoy (4 speed)
