need help on 2001 dodge ram serpentine belt without AC #654195
03/28/10 09:53 PM
03/28/10 09:53 PM
Louisiana
71cuda34o Offline OP
Louisiana
i have a 2001 dodge ram 360 and the AC cluth locked up, so now i want to bypass the AC and i bought a no AC belt and its too short. Any suggestions or help?
Re: need help on 2001 dodge ram serpentine belt without AC [Re: 71cuda34o] #654196
03/29/10 07:30 AM
03/29/10 07:30 AM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
if no one else helps you by tonight, I will dig out my truck and see what size belt I use on a Dak 360 where we removed the ac on it. Are you using the AC bracket or the non ac bracket? Because it does make difference in belt sizes.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: need help on 2001 dodge ram serpentine belt without AC [Re: 71cuda34o] #654197
03/29/10 12:37 PM
03/29/10 12:37 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
you need a 34178 motormite part number. its a bypass pulley to take place of compressor. that way you run the same belt you did before. my store sells it for about $40.
71 scamp big block with 915 heads 727 trans
Re: need help on 2001 dodge ram serpentine belt without AC [Re: 71cuda34o] #654198
03/30/10 10:19 PM
03/30/10 10:19 PM
Louisiana
Louisiana
Thanks for the answers guys, I went with a 90" belt and it bypassed the ac.
