440 w Holley 750, dual feed line - hits distributor.... #653783
03/28/10 03:21 PM
03/28/10 03:21 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Other than flipping this dual feed line over and using 42 feet of rubber line to get the firewall, or spending $3,000 bucks on AN fittings, has any one crafted up an alternative solution to this dilemma?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653784
03/28/10 03:23 PM
03/28/10 03:23 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Do you have a spacer under the carb?
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653785
03/28/10 03:26 PM
03/28/10 03:26 PM
Kirkland, Washington
Pacnorthcuda Offline
I flipped the feed line over and hardlined from the pump back along the frame rail, up the firewall and just used a short (4") section of fuel line to connect.
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: ireland383] #653786
03/28/10 03:27 PM
03/28/10 03:27 PM
Tennessee
Tennessee
Yes, I have a spacer - but it's only like a 1/2-inch one.
Wile E. Coyote
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653787
03/28/10 03:43 PM
03/28/10 03:43 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
I did the same thing Pacnorthcuda did..........
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: DartGTX] #653788
03/28/10 03:58 PM
03/28/10 03:58 PM
Tennessee
Tennessee
Yeah - that's sounding like a good idea - I just hate to bend it up and make it look "rigged". I s'pose I'll go buy some tubing and exercise my engineering personality. Thanks for the inputs.
Wile E. Coyote
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653789
03/28/10 03:59 PM
03/28/10 03:59 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
NOTE: Website link obsolete. Call directly!
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: Commando1] #653790
03/28/10 04:19 PM
03/28/10 04:19 PM
Tennessee
Tennessee
WINNER! WINNER! CHICKEN DINNER!!!
THATS what I was wanting Commando1!
Thank you very much for posting this!
Wile E. Coyote
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653791
03/28/10 06:23 PM
03/28/10 06:23 PM
Detroit, Michigan, USA!
peelerboy Offline
peelerboy  Offline
That's the exact fuel line set-up I have on my 383 w/dual feed Holley. It works perfectly. I can recommend with high confidence that product is a great solution.
Dale
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: peelerboy] #653792
03/28/10 06:31 PM
03/28/10 06:31 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Here's one I bent up a few months ago.
Stan
383man [Re: HemiStan] #653793
03/28/10 09:01 PM
03/28/10 09:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is the setup I used as I found this carb fuel line at a local speedshop. Ron
Re: 383man [Re: 383man] #653794
03/28/10 09:58 PM
03/28/10 09:58 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
heres what i fabbed. just pulled the motor yesterday but ran this for about 5-6 years so far.
Re: 383man [Re: 383man] #653795
03/28/10 10:05 PM
03/28/10 10:05 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i copied the idea for the bracket to relocate the coil from a magazine add. just some 1/8 steel plate.
Re: 383man [Re: 383man] #653796
03/28/10 10:11 PM
03/28/10 10:11 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
by the way, 383man, your engine and car are top notch.
Re: 383man [Re: dirtybee] #653797
03/29/10 07:39 AM
03/29/10 07:39 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Here is one I did for our old 64. It bends up to go over the vac advance, then over to the passenger side so it can drop down next to the alt to the fuel pump. Just get a coat hanger to rough it in and then bend up the line.
Re: 383man [Re: Dads426] #653798
03/29/10 12:03 PM
03/29/10 12:03 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I went under the vac advance. I don't have any pictures of it all together but it seems to work well.
Re: 383man [Re: Chilort] #653799
03/29/10 06:32 PM
03/29/10 06:32 PM
Commando1 Offline
Commando1  Offline
The stock factory routing of the solid fuel line from the fuel filter to the carb is one of the most toturous bent pieces I have ever seen! I have tried to duplicate it many times and there is just ain't no way....
I have yet to see anybody repop those.
Re: 383man [Re: Commando1] #653800
03/29/10 06:55 PM
03/29/10 06:55 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I got my stock style from inline tube. It fit pretty good right out of the box. A couple of little tweaks and it's allmost as good as NOS. Not bad considering i'm useing an Eddy carb not a carter. The inlet is close but not exactly the same as the carter..
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653801
03/29/10 07:01 PM
03/29/10 07:01 PM
AndyF Offline
AndyF  Offline
Been and issue for the past 40 years! (closer to 50 years)
Re: 440 w Holley 750, dual feed line - hits distributor.... [Re: WyleECoyote] #653802
03/30/10 07:19 AM
03/30/10 07:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
turn it around backwards
Coming soon!!!!
