exhaust manifold flange gasket for big block #652226
03/26/10 08:26 PM
03/26/10 08:26 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
Help!
I've got these in the past and can't seem to get the parts store to locate them.
Center hole ID is 2-1/2 inch
Bolt to bolt center is 4 inch
The ones that come with the kits does not match the hole to hole dimension
Thanks,
Mark
Re: exhaust manifold flange gasket for big block [Re: rutro] #652227
03/26/10 08:30 PM
03/26/10 08:30 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I would suggest getting some bulk gasket material and making yerr own.
Re: exhaust manifold flange gasket for big block [Re: dOrk !] #652228
03/26/10 08:55 PM
03/26/10 08:55 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you are talking the exhaust pipe to manifold gasket you should be able to go to a exhaust shop and get them. Bulk gasket material is not the answer as you should have a metal ring if not a complete tin gasket. Something like 'exhaust pros.'
Re: exhaust manifold flange gasket for big block [Re: MoparforLife] #652229
03/26/10 09:17 PM
03/26/10 09:17 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Re: exhaust manifold flange gasket for big block [Re: 69Cuda340S] #652230
03/26/10 11:23 PM
03/26/10 11:23 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Ultra copper rtv
Re: exhaust manifold flange gasket for big block [Re: MoparforLife] #652231
03/26/10 11:49 PM
03/26/10 11:49 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Yeah ... I would agree if you need the metal-ring type .. but on a free-flowing exh system .. I don't think that is necessary.
Re: exhaust manifold flange gasket for big block [Re: dOrk !] #652232
03/27/10 01:08 AM
03/27/10 01:08 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Should be Fel Pro 60025 $1.35 ea at Rock Auto..
I had to order somea couple of years ago for my Chyrsler 300 No one had them in stock, only the common gasket for the smaller flanges..
Re: exhaust manifold flange gasket for big block [Re: sthemi] #652233
03/27/10 04:46 PM
03/27/10 04:46 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
Got them finally!
Thanks everyone.
It's the little stuff that's frustrating.
