65 Hemi engine #651645
03/26/10 08:14 AM
03/26/10 08:14 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
I just found a 65 Hemi engine with a magnesium Crossram. It has the Vin (I think it's the vin) stamped in the block. In 65 weren't the Hemi's only in the factory drag cars?
Re: 65 Hemi engine [Re: LL340Rag] #651646
03/26/10 09:16 AM
03/26/10 09:16 AM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
Yep. It would be a race hemi. Street hemi's didn't come out until 66. Look for a casting date on the passenger side of the block.
That motor is either out of a A990 super stock, or was a spare motor for one. Very highly desirable and someone may be hunting for that. If it's not cracked or windowed, the value of that could be through the roof.
Re: 65 Hemi engine [Re: RC91] #651647
03/26/10 09:37 AM
03/26/10 09:37 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
65 casted blocks were used in 66 hemi street cars.
Post the casting date, top pad stampings and the
vin number at the pan rail if it has one.
Logan426
Re: 65 Hemi engine [Re: RC91] #651648
03/26/10 11:09 AM
03/26/10 11:09 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
No cracks or windows. 30 over clean bore. I 'll see if I can get the #'s off it, more so I am trying to get the engine.
Re: 65 Hemi engine [Re: LL340Rag] #651649
03/28/10 10:27 AM
03/28/10 10:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
65 casting date blocks could have been used in any 65-68 Hemi car, Race or Street Hemi. The cross ram would have obviously been correct for a Race Hemi if originally installed, etc. The VIN would not appear on any Hemi until 1968. You'd usually find the 68 model year VIN stamping on the upper rear of the block just opposite the oil sender. If it's a Race Hemi it would have also had unique stampings on the upper distributor ID pad. If it turns out to be a 65 casting date Race Hemi with a VIN# it's most likely a 68 Super Stock Dart or Barracuda engine. As mentioned, post all the pics you can of any numbers you find and it shouldn't be to tough to nail it down to one or the other.
Re: 65 Hemi engine [Re: ScottSmith_Harms] #651650
03/29/10 07:49 AM
03/29/10 07:49 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
So it's obviously worth trying to buy it. Any idea's on a number I should throw at him? He knows what he has at least Hemi wise.
Re: 65 Hemi engine [Re: LL340Rag] #651651
03/29/10 10:03 AM
03/29/10 10:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hard to say Larry, people all seem to have different opinions on vintage Hemis. An original 1971 engine, carbs to pan, 100% stock externally, just a grease ball yanked from a car early in it's life, went for 20K this weekend. Most consider a 1966 engine (usually considered the least desirable year) in similar shape to be worth roughly half that, so IMO, somewhere in that range would be about right. It's certainly a premium piece (if all or mostly there and unmolested) to the right guy.
Re: 65 Hemi engine [Re: ScottSmith_Harms] #651652
03/30/10 09:22 AM
03/30/10 09:22 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
The early (a990) blocks are nodular iron.
The 66 hemi was the only year they did not have a tufftried crank.
Re: 65 Hemi engine [Re: ScottSmith_Harms] #651653
03/30/10 11:41 AM
03/30/10 11:41 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
empty bare block I would think approx 40-50% over the cost of a new mopar bare block,?????
probably more depending on IF it can be determined what it's out of
Re: 65 Hemi engine [Re: gtx6970] #651654
03/30/10 02:35 PM
03/30/10 02:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Knowing if it's standard bore would help. If it's + .060, that should drop the price somewhat because it would likely be custom-piston time. If you can get your hands on a bore gauge, take one with you and check the bores.
Re: 65 Hemi engine [Re: topside] #651655
03/31/10 08:40 PM
03/31/10 08:40 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
Above post:
