Power Antenna #651484
03/26/10 12:09 AM
03/26/10 12:09 AM
Back home in PA
BulletBob Offline OP
Back home in PA
I bought a 5th Avenue power antenna to put in my CrewCab. What are the functions of each of the three wires. Does anyone have a diagram? thanks Bob
Re: Power Antenna [Re: BulletBob] #651485
03/28/10 02:05 AM
03/28/10 02:05 AM
Back home in PA
Back home in PA
Re: Power Antenna [Re: BulletBob] #651486
03/28/10 02:13 AM
03/28/10 02:13 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I am sorry this is such a general answer, but I believe they are power, ground, and a "radio on" lead which opens/closes it when the radio is switched on or off...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Power Antenna [Re: sycboi] #651487
03/28/10 02:54 AM
03/28/10 02:54 AM
Back home in PA
Back home in PA
The colors are yellow,brown & gray.Which does what? thanks Bob
Re: Power Antenna [Re: BulletBob] #651488
03/29/10 08:36 AM
03/29/10 08:36 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
what year Bob??? I have diagrams for several different types- but some are 2 wire and 3 wire connectors to the ant.motor!
Re: Power Antenna [Re: 71_deputy] #651489
04/01/10 09:34 AM
04/01/10 09:34 AM
Back home in PA
Back home in PA
85 or 86 It has 3 wires. Thanks Bob
Re: Power Antenna [Re: BulletBob] #651490
04/04/10 11:17 AM
04/04/10 11:17 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
Bob- can't find exactly your color setup- but I think as I'm looking at a 89 setup that the setup for yours is for a automatic type- it needs a special relay setup to work- you'll have to experiment with the colors to get it right!!!
it would be a double pole double throw relay- 12 volt coil
