Hello.
I'm finally swapping the crummy 2bbl from my '73 400 (Dodge Truck).
I was given a scummy ol' 400 Thermoquad intake from a '78 engine.
Question is, how do I deal with all the 70s emissions garbage? I don't have an EGR, so can I just make a thick steel block-off, squirt a lil RTV and call it a day?
Should I do anything with whatever this junk is on the intake floor? Fill the hole? (holes?)
Your thoughts?
Also, should I open-up the carb adapter to equal the Thermoquad size with a die grinder? (I'm using a Carter 4bbl, so the adapter is required on the TQ intake) Or not worth the effort? (Drag performance is not the reason for the swap, just reliability)
