Re: Brake pedal low and an inch of free play
[Re: Dougsmopars]
#649253
03/23/10 11:41 PM
03/23/10 11:41 PM
RapidRobert
How much clearance do you have between the rod rounded nub and the inside bottom of the M/C piston recess? and how did you check it? I'd unscrew the threaded nub until you have less than ~1/8"
[Re: Dougsmopars]
#649259
06/10/12 08:42 AM
06/10/12 08:42 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I am dealing with the exact same problem above, very sure of the rod adjustment between the MC and the booster. Anyone know/remember how this was solved? 68 b-body, hemi, power brakes with correct Bendix booster
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
