Re: How much $ to assemble a long block?
[Re: ccdave]
#649012
03/23/10 03:09 PM
03/23/10 03:09 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
It depends, are you talking about just bolting it together?
Or checking all the bearing clearances, coil spring bind, retainer to valve seal clearance, oil pump pickup clearance, piston to valve clearances, brush cleaning all of the oil passages, etc...
It could vary greatly depending on the work..
[Re: ccdave]
#649013
03/23/10 03:12 PM
03/23/10 03:12 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Generally i'll charge $1200/$1300 for a complete engine.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: DaveDudek]
#649014
03/23/10 04:02 PM
03/23/10 04:02 PM
the cost can vary greatly, depending on the complexity of the build. every engine build needs to have all specs and clearances checked and corrected, but some are cookie cutter type combo's (meaning you know what to expect) and others are much more complex. it would be hard to quote a price without having parts in hand, or at least knowing more about the engine in question. as an example, it take a lot more time to completely assemble a competitive stocker/ comp eliminator/ blown alky/ etc. etc. type engine than it will a 375 hp street 440 engine.
[Re: DaveDudek]
#649016
03/23/10 04:39 PM
03/23/10 04:39 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
Thanks Dave
Other guys, just take the "it depends" out of the mix and give me a ballpark
[Re: ccdave]
#649017
03/23/10 04:44 PM
03/23/10 04:44 PM
DaytonaTurbo
Manitoba, Canada
Thanks Dave
Give a little more info on the build. And are you having any machine work done or buying any parts from the place you want to do the assy? You may get a bit of a break on the assy rate if you throw them some other work as well.
[Re: DaytonaTurbo]
#649018
03/23/10 05:13 PM
03/23/10 05:13 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
My guess someone has done the machine work and he wants to know a fair price to assmeble the short block.
Every time I have paid someone to do this it broke. Twice was over piston to valve clearance was not properly check and the heads were at the shop but the gaskets just hadn't showed up. Screw that I assemble my own. Cost me a little in Micrometers as I don't care for plastigauge. A few years ago I had a line bore main job done and did not clean out the holes feeding the cam tunnel as I don't use them. Well that blew up and it was my fault. I'll still take my chances. 20 years one screw up on me. Four engines done by professionals four blowed up.
[Re: Leon441]
#649019
03/23/10 09:34 PM
03/23/10 09:34 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
The machinist that I use does mostly chevy work and he has a price list for work to be done. Asemb short block start @ $350, check deck hight $40, check piston/valve clearance $50, degree cam $75, set spring hight $50 ect, ect. He will do as much or as little as you want him to do. Ford and Mopar slightly higher, as usual. He also has a price list you can use for other stuff to, such as clean block, so much, disassemble complete engine, so much ect, ect. You can look at the list and get a good idea what it will cost you.
[Re: ccdave]
#649020
03/23/10 09:55 PM
03/23/10 09:55 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Question>>>>>>>>>> Quote:
Was wondering what it costs in labor to assemble a long block. This would include degreeing in the cam.
REPLY....>>>>>>>>>>>>>Generally i'll charge $1200/$1300 for a complete engine. ____________________________________________________________________________________________________________________________________________________________________________________IMO,This general price quote would include disassembly,clean,measure,coordinate machine work,reclean,remeasure,order all needed parts and assembly.All parts and machining is more depending and what acually needs to be performed.
[Re: b1dartsport]
#649023
03/23/10 11:44 PM
03/23/10 11:44 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
The speed shop In my area charges $750 if all clearances have been already checked & it is ready to assemble. What this means is that is the final charge to put it together after all the parts are prepared, checked & machined by them.
After ALL the parts are prepped, checked and machined ? ... ?
Well ...a drunk MONKEY could put together the SB then.
That is CrAzY .... what kind of knowledge or expertise is there just doing that ?
[Re: dOOc]
#649024
03/23/10 11:56 PM
03/23/10 11:56 PM
Posts: 982 western pennsylvania
b1dartsport
Ya got me there...but thats their price,take it or leave it
[Re: dOOc]
#649025
03/24/10 12:11 AM
03/24/10 12:11 AM
i guess that makes you qualified.
even though things may be machined, you still have a lot to check and verify. it's not like you could just throw it together and expect it to be right, or know what you have, other than a bunch of parts bolted together.
#649026
03/24/10 12:43 AM
03/24/10 12:43 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Even if I were to check Nothing and just Bolt up all the parts and Drink like a Drunk Monkey, Id want at least $500 to do the job. "INSTALL/BOLT" Long Block.
Rings, Rod bearings, Rod caps and bolts, Crank Main Bearings,thrust bearings,End gaskets, Main caps and Bolts, Oil pump pickup tube, Oil pan and bolts, head gaskets ,head and head bolts, camshaft,lifters,pushrods,rockers and rocker shafts and bolts and shims. Timing chain, gear and crank gear. Index cam to a desired ICL ETC,ETC,ETC ETC
[Re: Sport440]
#649028
03/24/10 01:04 AM
03/24/10 01:04 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
We do it like this: Proud owner of engine comes home with all his parts from the machine shop... Buys Pizza and Beer, and calls us all over... After many stories, and proper lubrication, 4 or 5 drunk monkeys put it all together... Cam break-in commences at 1AM!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#649029
03/24/10 01:20 AM
03/24/10 01:20 AM
Sport440
Canton, Ohio
If there are 4 or 5 drunk monkeys involved in putting it together with plenty of Pizza and Beer and Fun, Its all about the Sport, no pun intended. mike
#649030
03/24/10 02:01 AM
03/24/10 02:01 AM
dOOc
Florida STAYcation
i guess that makes ME qualified.
dHam .... I FIXED yer post ...
