Re: Heat Range
[Re: emarine01]
#648915
03/26/10 10:54 AM
03/26/10 10:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thankx Ian, Raff mentioned a lean out valve in a post for alki cars, I was thinking of trying it to clean the plugs and cut down on the warm up time, we heat soak for alu rods before we run, any one see any problems with doing this with gas?
It shouldnt hurt anything... most it would do if you lean it out too much is stall it out(we are talking idle here) I have NGK 9 in my W-9 on E-85 14:1 but I think I am going 1 hotter on mine
Re: Heat Range
[Re: Cab_Burge]
#648917
03/26/10 04:39 PM
03/26/10 04:39 PM
Posts: 3,695 nc
emarine01
nc
Sounds like you need to lean out the idle and part throttle circiuts to clean up the low end
I have the idle pretty lean and we don't see any part throttle for the most part, running up the ramps on the trailer is about it, It takes a wile to get the plugs black <a few weeks of racing> I think my pump shot is as long as a pass around 3.5 seconds, I leaned out my BG 1000 from 90s square to 87s to see if it would clean up and it didn't, just slowed down 3/100ths so I have been trying hotter plugs to see what happens, I have 6s ngk in there for about 2 weeks and they are clean, from what I can tell I have not fryed anything yet but dont want to figure this out the hard way also
