Regulator Mount #647636
03/22/10 10:36 AM
03/22/10 10:36 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
SO I have been working on a new regulator mount for my cuda... so here is what I came up with.
The reg is free hanging from aluminium fuel lines...anyone see any problems with this on a street car.
Jason
Re: Regulator Mount [Re: CUDAJAS] #647637
03/22/10 10:43 AM
03/22/10 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... fatigue of the alum line... hanging it in
space is fine but with a flexible line.... looks
good though
Re: Regulator Mount [Re: MR_P_BODY] #647638
03/22/10 11:13 AM
03/22/10 11:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
fire hazzard if you ask me. why don't you get the jegs reg mount and use flex lines. it does look good but an accident waiting to happen
Re: Regulator Mount [Re: Quicktree] #647639
03/22/10 12:48 PM
03/22/10 12:48 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Thanks guys...well back to the drawing board!
I wanted to go with the jeg's reg mount, but it looks like my drop-base air cleaner will hit the reg. I think I will mount the reg on the inner fender for now.
Hmmm..I also ran aluminium lines front to back (upgrade to 3/8 from 5/16). The lines are securly fastened at several points... should I be concerned about that too?
Re: Regulator Mount [Re: CUDAJAS] #647640
03/22/10 03:49 PM
03/22/10 03:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
solid lines to the front should be fine if they are secure. but run braided or the new black flex lines to the carb.
Re: Regulator Mount [Re: Quicktree] #647641
04/03/10 09:13 AM
04/03/10 09:13 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Thanks guys...
Do you think hanging the regulator by steel lines would work / be safe. I really do not want to use braided lines.
