1/2 vs 1.5 ton...let's compare.
#647588
03/22/10 12:46 AM
03/22/10 12:46 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
In regards to '39-'47 trucks, a lot has been said about the differences between 1/2 tons and 1.5 tons(and larger). The general consensus has been that the cabs are the same, hood/grille may be the same but the fenders are definitely bigger. I admit that I thought this to be true also. Some have read my other thread regarding the multiple trucks and parts I've recently begun collecting. As a result, I have several fenders/hoods/grilles etc. cluttering up my life. I couldn't be happier! I took an afternoon and did some comparisons of these parts. Here's what I found. Cabs are the same.
Cheeto It's not perfect. It's not correct. It's not yours!
Re: 1/2 vs 1.5 ton...let's compare.
[Re: Cheeto]
#647589
03/22/10 12:48 AM
03/22/10 12:48 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Hoods are the same Although one of these hoods has nearly 1/2" difference from side-to-side. I'll chalk that up to "production variances" or repairs made over the past 60+ years.
[Re: Cheeto]
#647591
03/22/10 12:58 AM
03/22/10 12:58 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Fenders. You tell me which is 1/2 ton and which is 1.5 ton.
[Re: Cheeto]
#647593
03/22/10 01:03 AM
03/22/10 01:03 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
255/55-18 Sorry, it's the only wheel/tire I had loose and available besides the 37" off my big truck.
[Re: Cheeto]
#647596
03/22/10 01:24 AM
03/22/10 01:24 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Now the real puzzler. You looked at the fenders right? Did you see a difference? Could you tell which one came from which truck? I measured the dang things in several areas and found nothing that couldn't be explained away by production variance or 60 years of abuse. Admittedly, I wasn't using a square and straightedge to ensure I measured the exact same spot on each fender. None of the measurements varied more than about 1/2" between the two though. I measured the wheel opening, the distance from inner edge to headlight mounting holes, from the inner edge over the hump to the fender lip and from the inner edge straight to the fender lip from underneath. As I said, negligible differences until...
[Re: Cheeto]
#647597
03/22/10 01:51 AM
03/22/10 01:51 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
The yokes. Due to varying brackets I couldn't get these to line up perfectly but...remember those bumpers? Yup, you guessed it. Approximately a 4" difference. I can't explain it. Maybe the brackets attached to the fenders are different? Maybe there is enough flex in the fenders that they give enough to make up the difference? I only checked full width on these. I'll go back and measure from centerline-to-tip for each side on both. Maybe one of them is tweaked. Dragging all this iron around the yard had my Scoliosis demanding I call it a day. I just wanted to get this info out there and hopefully open up a little discussion on the topic. Any suggestions or hypotheses?
[Re: Cheeto]
#647598
03/22/10 01:55 AM
03/22/10 01:55 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Just for those who dig old iron, here's some more pics of the bits and pieces I've gathered up. Enjoy. Somebody punched in that rear fender to make room for a spare tire mounted to the bed (visible in the first pic on this thread).
[Re: Cheeto]
#647599
03/22/10 01:59 AM
03/22/10 01:59 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
According to what I've read, the trim strips indicate this clip is from a '41 or '42.
[Re: Cheeto]
#647600
03/22/10 02:02 AM
03/22/10 02:02 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
The free dump truck I still need to go get. Thankfully he's cutting the box off so I can get it in two trips. I don't think my trailer would handle it whole.
[Re: Cheeto]
#647603
03/22/10 10:42 PM
03/22/10 10:42 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I'm supprised to see both the 1/2 ton and the 1 1/2 ton fenders are the same. I have to wonder if the 1/2 ton you have got the big truck fenders somewhere along the line? I have read multiple places the big truck fenders had larger wheel openings then the 1/2 & 3/4 ton trucks had. Maybe that went away during the war years? Most trucke produced during the war would have been bigger trucks, might be such a thing as all the trucks got the same fenders after 41? By looking at the mounting brackets, I also wonder if the big trucks angled the bottom of the fenders out a bit more to clear the bigger tires? I would think that nose with all the chrome would have to be pre war, 39-41. Chrome was a valuable war commodity, anything produced during the war would have had mimumium chrome. You have quite a collection going there! Do I have to be on guard of those big truck fenders I got from the scrapper guy a couple years ago? Gene
[Re: lunacy]
#647605
03/23/10 01:10 AM
03/23/10 01:10 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
very kool topic,,and glad ur saving all this IRON,,, im really starting to like the 41 ply trucks,,always loved the 57 dodge....
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Cheeto]
#647606
03/23/10 05:32 PM
03/23/10 05:32 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Nose cones are the same. Including the bumper bracket openings. Don't ask me why the one upper portion is painted "chrome". That's the type of treasure you get when you buy a truck in pieces.
Awesome score! If you have just the center grille section that you want to part with at a real fair price please pm me. I will consider the rustiest one you got
