Carter Themoquad adjustment #646836
03/21/10 12:09 PM
03/21/10 12:09 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
I have a Carter Thermoquad 4 barrel on a decently built 340. The thing runs so rich the flies drop dead around it. It has just been rebuilt but not setup yet. Other than the 2 basic screws how do you lean this thing out?
Re: Carter Themoquad adjustment [Re: LL340Rag] #646837
03/21/10 01:11 PM
03/21/10 01:11 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
You might want to thumb through this. The adjustments need to be done in a specific order.
Imperial Club
Any idea on jets and rods? Are they stock? Is that an original 340 or small block carb?
Do you know if the carb. rebuilder replaced the o-rings in the bowl area? They can leak and lead to a rich condition (see p.11).
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Carter Themoquad adjustment [Re: DynoDave] #646838
03/21/10 01:55 PM
03/21/10 01:55 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
Jets and rods are stock. It is a 72 340 carb 6133S I believe. Correct for a 340. Everything was replace in the rebuild. I believe I just need to adjust the metering rods, just not sure how and the manual is little help.
Re: Carter Themoquad adjustment [Re: LL340Rag] #646839
03/21/10 02:15 PM
03/21/10 02:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Carter Themoquad adjustment [Re: 70AARcuda] #646840
03/21/10 02:30 PM
03/21/10 02:30 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
Thanks. More work.
Re: Carter Themoquad adjustment [Re: LL340Rag] #646841
03/21/10 02:32 PM
03/21/10 02:32 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
did they reseal the jet wells?
Re: Carter Themoquad adjustment [Re: LL340Rag] #646842
03/21/10 03:30 PM
03/21/10 03:30 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Who rebuilt it ? .. I ask this because some people mix-up big-time the primary rods and jets. Is this rich through ALL the cycles? ,...what floats are in it?
Re: Carter Themoquad adjustment [Re: dOc !] #646843
03/21/10 03:35 PM
03/21/10 03:35 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I'll second checking the resealing of the jetwells. Also check the float height. I has to be checked with the gasket in place. Measure from the gasket surface.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Carter Themoquad adjustment [Re: Rug_Trucker] #646844
03/21/10 03:58 PM
03/21/10 03:58 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
What is all this JET WELL chat ? ... is this what you guys have seen lots ? ... I have rebuilt more than my share of TQ's .. but I have only seen that prob once.
Which year/model carbs are prone to this issue ?
Re: Carter Themoquad adjustment [Re: dOc !] #646845
03/21/10 04:18 PM
03/21/10 04:18 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
It was rebuilt by a shop that has done hundreds. I knew it had to be setup since my engine is far from stock. I just don't remember how since it has been a long while.
Re: Carter Themoquad adjustment [Re: dOc !] #646846
03/21/10 04:23 PM
03/21/10 04:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i think al the 72 and later ones, i have only rebuilt one and it leaked, its the two small bumpes on the bottom of the bowl the jets screw into the well area. i just checked it by adding water to the bowl when apart and looking for a drip or moisture around the factory sealer.
Re: Carter Themoquad adjustment [Re: LL340Rag] #646847
03/21/10 05:25 PM
03/21/10 05:25 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I've rebuilt a number of TQ's, and all the ones I've done, you could see the metering rod adjustment screw when the metering rods were up. I can't see yours in the pic (screwed in too far would make it rich). Not conclusive by a long shot, but, one of the first things I'd check.
I've had the leaking wells too, but, it was always on a TQ that was on a car with Lean Burn.
John
Re: Carter Themoquad adjustment [Re: SattyNoCar] #646848
03/21/10 09:27 PM
03/21/10 09:27 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
That's what I am looking for. Where are the rod adjustment screws supposed to be?
Re: Carter Themoquad adjustment [Re: LL340Rag] #646849
03/21/10 09:33 PM
03/21/10 09:33 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
That is only ONE screw ...and the height-spec is not "standard" .. it can vary. Do you have a pic of yours?
And is your rich-situation through all ranges of operation ?
Re: Carter Themoquad adjustment [Re: LL340Rag] #646850
03/21/10 09:54 PM
03/21/10 09:54 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Bottom your metering rod tree by turning screw CCW and then turn the screw 1 turn CW just as you see the tree start to raise for stock setting.
1.5 turns out on the idle mixture screws is a good starting point.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Carter Themoquad adjustment [Re: dOc !] #646851
03/22/10 06:52 AM
03/22/10 06:52 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
Where is the one screw on the carb supposed to be. The small one in the center triangle? I know it is not standard. I just need to play around with it. It is rich through everything. It runs nice but is massively rich to the point of having to change my clothes after 30 seconds of running.
Re: Carter Themoquad adjustment [Re: LL340Rag] #646852
03/22/10 11:03 AM
03/22/10 11:03 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Hmmmm, is the float level too high ?? Yes, the rod adjustment screw is the one in the "triangle" as you pointed out. When the car is running, vacuum pulls the rods down (with the stepped rods in the jets, this effectively changes the size of the openings (i.e. lean or rich). . . the screw allows adjustment of this . . .
Rather than playing with it too much, is there a shop nearby that has a mechanic that knows carbs (not many of the breed left !!!) and would be able to hook it up to an exhaust analyzer ? Then you know for sure that you are adjusting things correctly.
Is the choke on ? Oh sooo many questions . . . check out the attached link :
http://carburetor.ca/pdf_manuals/Carter/1972TQmanual.pdf
TQ's are great carbs, but really need to be adjusted in sequence . . . happy tuning. . .
Cheers
Mark
Re: Carter Themoquad adjustment [Re: a12rag] #646853
03/22/10 11:38 AM
03/22/10 11:38 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The metering rod spring hanger (the long arm the rods go on) has a sngle piston in the center. The screw head you see is the top of a long rod that goes downt o the bottom of the baseplate. The lever in the baseplate works like apower valve t force the rods out of the jet, richening the full hrottle mixture to the max the jet and rod will flow whetehr there is vacuum or not. At all other times and throttle openings, the rod hanger is controlled by engine vacuum operating against the step up spring, which is under the piston on the rod hanger. If you engine is not stock, my impression is the factory spring is incorrect and pushing the rods to the rich end of the spectrum all the time. You can adjust that center screw all you want, if the spring isn't properly matched to the combo, you'll be either rich or lean all the time except full throttle.
Re: Carter Themoquad adjustment [Re: dOc !] #646854
03/22/10 12:32 PM
03/22/10 12:32 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Yep I just pop the wells off on any rebuild, restick them. I have pulled some apart that the wells completely drop off. I redo them with JBQuick or regular JB if I'm not in a hurry to put it back into service.
Re: Carter Themoquad adjustment [Re: Rug_Trucker] #646855
03/22/10 04:57 PM
03/22/10 04:57 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
I had gotten it a lot better this morning. Next I need to adjust the float bowl. Then I ran out of gas and had to go to work. I have a shop with a great mechanic that knows TQ's well but the car isn't on the road yet. It's my 71 Demon.
