might have slightly,I never checked it
just had it alined to 73 specs and put skinnys on the front 3.5x15-165/15 combo
the large brake axles moved the rear out 1/4 per side used 7x15 with 4.5 bs -245/60/15 combo on the back
filled the rear well up and looked good as the rear tire coverd the front tire tracks in the dirt
A-body have a narrow trac on the rear which is funny looking stock
got mine all squared up and handled good on the street
may just want to swap the power box and lower part of the colum to box...keep the 68 coulm in the dash
wired up diff for sure
mine was a manual steer before and after the swap
IMHO,I would find a whole 68 manual steer set up and use that...gonna be super tight with 440 and power steering box in there
headers are a PITA for sure for either SB-BB combos with power
still running the /6 t-bar up front?
I did on mine to get the weight tranzfer to the rear on launch
just wont like high speed turns though...
and at 125 mph...when you let off all the way at the end of the 1320 be ready for nose drop
it seemed mine would drop 2 feet on decel
good luck
killer looking 440 in the fish also
