Re: 440 trucks
[Re: 70Challengerse]
#6449
05/09/06 07:47 PM
05/09/06 07:47 PM
Posts: 762 Ca
76440
Ca
Just ordered the swicthes for the swap , No the truck IS not painted, and brown or red,does look brown..
Did your big converter fit or will you be grinding? ![](/ubbthreads/images/graemlins/beer.gif)
Any more pics maybe a straight shot of the trans after the cut? ![](/ubbthreads/images/graemlins/drinking.gif)
Re: 440 trucks
[Re: 76440]
#6450
05/09/06 09:48 PM
05/09/06 09:48 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
Forgot to add that Mike, so far with everything I have done,as far as checking what I'm gonna have to add or to delete,so far the torq WILL fit,looking like it is gonna have enough clearance(was really happy there),so far just the shifter bracket and modify the crossmember and find a drive shaft to cut down 3 1/2 inches down,the mods with the vacum switch and pressure switch is my thing,I don't want to do it twice,and switch the toggle switch,I want it to work on its own,been putting some descent parts away for the last year or so,5 pinion front steel 4 pinion low/reverse and 4 pinion overdrive 15 degree(alittle more strenght) and quiet,using the old style big block 2nd apply servo and acouple mods.....should be finished this weekend and some of the truck NEXT..weekend. ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: 440 trucks
#6464
05/14/06 10:09 PM
05/14/06 10:09 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
Looking good Ric ![](/ubbthreads/images/graemlins/shock.gif) But man you better get a move on. ![](/ubbthreads/images/graemlins/drive.gif) It's only 53 days until Carlisle. You got a long way to go and a short time to get there. But it does look good so far. ![](/ubbthreads/images/graemlins/beer.gif)
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
