Re: 505 quench with rb block
[Re: 1964maxwedge]
#646017
03/20/10 01:22 PM
03/20/10 01:22 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
It's my understanding that with the thicker head gasket you've decribed, you will be just beyond the boundries of effective quench.... With the thinner gasket, you will be at an acceptable quench, but with iron heads, your ability to tune for 93 octane fuel will be wholey dependent upon you camshaft selection.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dOc !]
#646019
03/20/10 04:47 PM
03/20/10 04:47 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
I would go with the thinner gaskets. You would probably get some benefit as is, but below 50 is better. Gaskets are easy! I just saw the 11-1 part, good luck! you may want to dish the pistons on the valve side, or some deep valve reliefs.
