Wheel backspace ? #645780
03/20/10 10:37 AM
03/20/10 10:37 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
Can anybody tell me how wide a 15" rim and tire I can go on a 70 Road Runner without playing with suspension? Also what backspace would I need on 15x10 wheels? Thanks.
Re: Wheel backspace ? [Re: tt455] #645781
03/20/10 03:46 PM
03/20/10 03:46 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Anybody? I did a search but didn't come up with much.
Re: Wheel backspace ? [Re: tt455] #645782
03/20/10 04:18 PM
03/20/10 04:18 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Good info here to measure for yourself.
https://www.rsracing.com/tech-wheel.html
Re: Wheel backspace ? [Re: Pntastar69] #645783
03/20/10 07:06 PM
03/20/10 07:06 PM
niagara, ontario
gers1968rt Offline
gers1968rt  Offline
niagara, ontario
If you have 5.5 to 6 inch backspacing you'll be ok. Gerry
Re: Wheel backspace ? [Re: tt455] #645784
03/20/10 07:59 PM
03/20/10 07:59 PM
Eastern North Carolina
riverman Offline
riverman  Offline
Re: Wheel backspace ? [Re: tt455] #645785
03/21/10 05:42 AM
03/21/10 05:42 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks for the info guys.
Re: Wheel backspace ? [Re: tt455] #645786
05/11/10 09:58 PM
05/11/10 09:58 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Well I tried to put a 15x10 centerline wheel with 6" of backspace with a mounted 275/50/15 drag radial on and it was a no go,right up against the fender lip.Looks like you need at least 7" of backspace.
Re: Wheel backspace ? [Re: tt455] #645787
05/11/10 10:33 PM
05/11/10 10:33 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
5.25-5.5 Basically 5.5 and if the tire is really big you may need a .25 spacer on one side but not the other. This is only if you have the factory b body rear end.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Wheel backspace ? [Re: tt455] #645788
05/11/10 10:35 PM
05/11/10 10:35 PM
So Cal
So Cal
With a 275/50 you will have plenty of room. It’s just when you have a tire approaching 305-335 it gets really close.
