Re: ROCKERS ARE CLOSE!!
[Re: Moparnut426]
#644910
03/21/10 10:36 PM
03/21/10 10:36 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
So with the 630-16 locks, do I need to run caps? Im assuming I do, but I dont know 100%
Kasey
No. We did not run a cap with that lock. Shouldn't need to as it is only changing the position of your retainer(.050 further away from the top of the valve)
[Re: Moparnut426]
#644912
03/21/10 10:48 PM
03/21/10 10:48 PM
cl440
S.E. Michigan
m also running the Tool Steel retainers, so there is TONS of room on the edge of the spring. Looks too small, but I am told they are the correct ones. Now I just have to pull the head off the passenger side, and buy 1 head gasket.
Kasey
We run tool steel retainers also. They to look smaller on the spring than I thought they should but have been running for 2 seasons (going into season 3) now with no problems.
[Re: Moparnut426]
#644913
03/22/10 02:06 AM
03/22/10 02:06 AM
since the -.05 retainer seems to be your choice of fixes, will you still have the proper installed height and pressures?
[Re: Moparnut426]
#644915
03/22/10 08:16 AM
03/22/10 08:16 AM
Posts: 1,178 Indy
FlyFish
Indy
You could also try some smaller diameter springs like these: http://www.summitracing.com/parts/LUN-73899/They are 0.050 smaller in diameter than the 943's, and about the same spring rate.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
